SCWDP911's Avatar
DE question - cab broomstick check?
Hello all. Been away a bit. I noticed our local PCA club (Mid-South Region) is having a DE at the end of April. The hitch is, I have a cab (83). Right now, my car is basically stock other than rebuilt top end with some upgrades, turbo tie rod ends, and other small misc. I do NOT have a roll bar. Our Mid-South Region website said that the cab drivers had to have a roll bar and pass a "broomstick" check? This would be my first DE. Can one of you veterans clue me in on this broomstick thing, or point me to a link where I can read the right info.
Thanks,
Dazed and Confused
Old 01-26-2007, 08:47 AM
David in VA's Avatar
As far as I know the broomstick test is used for Boxsters, I guess you could do the same thing on a cab with a roll bar. Basically you put a broomstick from the windshield to the roll bar (on top of both), the top of your helmet must be a certain distance below that. I think it's two inches. I don't see how you could do the test without a roll bar though.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 01-26-2007, 08:53 AM
SCWDP911's Avatar
ahh...
Thanks David,
That makes sense about the broomstick check, but makes me wonder. I am not that tall, 6'1". But with a helmet?? My car again, is an 83 cab. Anyone out there that can tell me what roll bars would work for my car and height? Is it possible to have all of this and still be able to use my top with the roll bar still installed?
Thanks,Shane
Old 01-26-2007, 08:57 AM
"O"man(are we in trouble)
widgeon13's Avatar
11. All open cars, including cabriolets and Boxsters, must have a visible, approved roll bar which
conforms to the following: With the occupant(s) (student and instructor, if applicable) firmly and correctly
belted into the vehicle, the occupant(s) helmet must be below a straight line drawn between the top of the
windshield and the top of the roll bar (clearance in a “Broomstick Test”). It is further recommended that
roll bar be padded in any area that may come in contact with the occupant(s) helmet. Participation of open
cars requiring instructors will be limited at each event based on the number of volunteer instructors who
pass the “Broomstick Test”.
This was extracted from a PCA track guide published by Ct Valley Region
Old 01-26-2007, 09:05 AM
SCWDP911's Avatar
Shane
- 1984 928S
Old 01-26-2007, 09:14 AM
