Leaking Past Valve Cover Bolts
I have oil leaking past the bolts on my lower valve covers and it is dripping on my exhaust.
My shop replaced the gaskets and bolts 8 months ago but I was still leaking oil - so they did them again under warranty. Just got it back tonight and noticed that oil is STILL leaking at the bolts (just 2 of them though). If anyone can help I would greatly appreciate it - thanks!
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
First I would make sure they are not warped with a straight edge or laying them on a flat surface. If they are straight you can try some upgraded gaskets that have a silicone bead or for a few more bucks go all silicone. Its also important to tighten these bolts to the correct torque.
Walt 82SC 3.0 81SC 3.6 |
Supposedly they are perfectly flat and the gaskets have the silicon bead.
The gaskets themselves are dry - oil is just coming through the last two bottom bolts closest to the rear. Are there other possibilities besides a warped cover and insufficient torque?
Are you sure the leak is coming from the cover. Sometimes oil can leak from above and find its way down to the valve cover. I spent weeks thinking I had a valve cover leak until I found the real problems.
Cracked rocker shafts will cause leaks as you describe.
'17 Cayenne |
Have you already upgraded to Turbo valve covers? I assume you know about this upgrade - most do - but if you don't, the earlier covers can warp at temperature. Its probably NOT your problem but has to be eliminated before searching for the next possible source. Good luck.
Dan in Pasadena '76 911S Sahara Beige/Cork |
I do have the turbo covers and I am sure that the leak is coming through the bolt - I do, however, have other very minor leaks but this is the one that drips onto the exhaust creates smoke.
The entire engine has been cleaned up on 3 separate occasions in order to determine the source of the leaks. When I inspected the underside last night, everything was PERFECTLY clean except for the drops of oil forming around the valve cover bolts. Also, is it bad if the valve cover gasket extends beyond the cover? I can actually touch the gasket with my finger. thanks
Clarification ......... the 'touchable' gasket is not on the same side where oil leaks through the cover bolts.
Mine leak too, everytime I do a valve adjustment I always replace with new nuts. I put a small dap of silicone on each nut. It seems to take care of the problem.
1976 911 S Targa 3.2 |
I'm hoping someone like John Walker or Grady Clay enters this discussion.....My personal feeling is that we need special washers for the valve cover bolts...those that have a "built-in" elastic/rubberized washer on their ID..and the rest is metal. I have a number of these parts on my Toyota valve cover through-bolts as Toyota OEM...and they work.
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil, while those type of washer, or a dab of silicon may help from oil leaking from the bolts, these should not be required, because the valve cover gasket surrounds the studs and should isolate them from any oil. So if you studs are dripping, the valve cover gaskets are still leaking, albeit inside the valve cover and possibly only surrounding the stud.
New nyloc nuts (which are required as per spec) may also help in this regard. |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
so ... any thoughts on the gasket being 'touchable'?
Just throwing this out there, did they replace the aluminum washers along with the nuts?
1976 911/S/SC/BASTARD Mid9 Member #12 |
Friend of Warren
As many valve adjustments as I have done on 911 engines I have never had leaks from the valve cover studs. Like klaucke pointed out, if you have a good gasket and a flat valve cover there is no way for oil to reach the valve cover studs.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Forced Induction Junkie
I had one leaking on the top stud around #5 exhaust ever so slightly. Tried new nylocks and washer to no avail. Took Curil T and applied it to both sides of the aluminum washer and a tiny bit to the stud threads. No leaks for over two months.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
resident samsquamch
I have a new engine and as part of the routine am running with new nylocs, washers, and silicone valve cover gaskets. Only slight torque has been applied and I've got what looks to be some leaks around a few of the nylocs. I've added a little more torque to the nuts, but have a couple that are still weeping. At first I was thinking that my rocker shafts (with RSR seals) might need another turn, but it really does look like the oil is weeping from the nuts! Maybe I'll try to add something to seal the nuts. I like Wil's idea about special washers.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
So what happened here??
1967S Porsche Targa #500317S EURO 1972 BMW 2002Tii 1967 Triumph TR4a Irs 1967 Austin Healey "Bugeye" Sprite 1966 Austin Healey 3000 MKIII |
Go get new washers (flat, aluminum) and self locking nuts. The shop may have reused the old ones which can contribute to leaks like you are describing. If you can't find the washers and nuts locally, let me know and I will send you a couple.
Good luck!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Autodidactic user
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
