Good luck
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
I'm a little worried. Per Howard's website (link above), the specs are I think considerably different between the stock 0-280-150-158 injector, and the suggested replacement 0-280-150-364. Here are the specs Howard has posted: BOSCH LBS/HR CC/MIN GRAMS PSI BAR ..158 21.8 229.1 164.8 36.25 2.5 ..364 25.7 270.1 194.3 43.5 3 are there any long-term users on the 0-280-150-364 injector that can report back? Jim |
You have to take into account that they are specified at different fuel pressures.
364 has 20% more flow but at 20% higher preassure, it isn't a 100% linear relationship, but pretty close.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Now I just hope I got everything on my shopping list here at Pelican for the job! Jim 1985.5 944 N/A |
If you could give us some feedback on your experiences with them, I'm sure it would be greatly appreciated. Thanks, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
I got a set of 364 from Howards and installed them on my car. Ran way better than the original set which was definitely not working properly IMO.
'87 3.2 Targa |
I did test the 364s thoroughly against the 158s in my car. The test was done by logging the AirFuelRatios of a 2nd gear WOT run with my WideBandO2 recorder. The results are above in post #206. Bottom line: the 364 is a very nice near perfect match to the 158 - I have been running the 364s for about 3000miles now with no issues.
I recently installed a set of low impedance GM Multec's PN 17103001. The first thing I noticed was a much smoother idle and when driving off, much more torque off the line.
I had my neighbor across the street who just bought an 89 3.2 try it out and was impressed as well. When he finally gets tired of the ho hum performance of his newly acquired car, we might be installing a set of these injectors in his too. Cheers, Joe 74 911 w/ late production 86 3.2 Last edited by stlrj; 03-02-2010 at 10:35 AM.. |
Cool thread, lots of good info here.
If there is someone in the SoCal area who wants to experiment with the different injector options, I'll provide some dyno time
Just to be sure is this what I want for my 88?
BOSCH 0280150360 Multi-Port Injector Motorman does not list a 364 but says he will make a 360 a 364 if you want. I don't see a 158 or 159.
Rick 88 Cab |
Applications:
BUICK 1984 SKYHAWK CUSTOM 1.8L 4 Cyl. Fuel Injector BUICK 1984 SKYHAWK T-TYPE 1.8L 4 Cyl. Fuel Injector BUICK 1985 SKYHAWK T-TYPE 1.8L 4 Cyl. Fuel Injector BUICK 1986 SKYHAWK T-TYPE 1.8L 4 Cyl. Fuel Injector PONTIAC 1984 J2000 SUNBIRD 1.8L 4 Cyl. Fuel Injector PONTIAC 1984 J2000 SUNBIRD LE 1.8L 4 Cyl. Fuel Injector PONTIAC 1984 J2000 SUNBIRD SE 1.8L 4 Cyl. Fuel Injector PONTIAC 1985 SUNBIRD 1.8L 4 Cyl. Fuel Injector PONTIAC 1986 SUNBIRD 1.8L 4 Cyl. Fuel Injector PONTIAC 1986 SUNBIRD GT 1.8L 4 Cyl. Fuel Injector PONTIAC 1985 SUNBIRD LE 1.8L 4 Cyl. Fuel Injector PONTIAC 1985 SUNBIRD SE 1.8L 4 Cyl. Fuel Injector PONTIAC 1986 SUNBIRD SE 1.8L 4 Cyl. Fuel Injector PORSCHE 1983 944 2.5L 4 Cyl. Fuel Injector PORSCHE 1984 944 2.5L 4 Cyl. Fuel Injector PORSCHE 1985 944 2.5L 4 Cyl. Fuel Injector It just so happens the GM multec injectors I installed, PN 17103001, were off an 86 Pontiac Sunbird. So it seems that Motor Man does know what he's talking about. BTW, they're a whole lot cheaper when you get them up from your local auto recycler. Cheers, Joe 74 911 w/ 86 3.2 Last edited by stlrj; 04-30-2010 at 02:17 PM.. |
Sal
Did you have to make any adjustments when you ran the 360 injectors or were they fine right out of the box?
Rick 88 Cab |
Just a quick update. Just installed a set of low impedance Quad Four injectors from an 92-98 Pontiac Grand Am...so far so good. They seem much better, higher flow meaning more zoom than what Motor Man recommends.
Cheers, Joe |
Senior Member
Joe,
Any guess on mileage? About the same or higher?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Better mileage. Took a round trip to Reno from the bay area and got 31.5 mpgs. And that was with my miles based on my GPS and not my highly inaccurate odometer.
Joe Last edited by stlrj; 05-04-2010 at 07:29 PM.. |
I use Accel for my EFI setup. work great.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Has anyone bought these from motorman lately? Howard doesn't seem to answer his e-mail.
Rick 88 Cab |
Those are not the right injectors you will need that Motor Man lists. If you get a hold of him, tell him you need Quad Four injectors from a 92-98 Pontiac Grand Am.
Cheers, Joe |
The Table below tells it all (fuel injector flow rates).
When you compare the flow rates, be sure to adjust for the fuel pressure rating (e.g. the higher fuel pressure should have a proportionately higher flow rate -assuming a linear response in the operating range) From the Table: 0-280-150-158 (flow is 229.1 cc/min at 36.25 PSI) 0-280-150-360 (flow 270.1 cc/min at 43.5 PSI) 0-280-150-364 (flow 270.1 cc/min at 43.5 PSI) fuel injector flow rates
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') Last edited by Jascha; 05-08-2010 at 03:17 AM.. |
For the GM injectors in question:
17103001 (flow 206 cc/min at 43.5 PSI) All things being equal, would suggest a lower fuel delivery than 'stock 158' injectors (!)
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
