make a difference? My first month of ownership on my '76 911 is mixed. I pumped regular gas in my car and it and now it won't start right. I thought it was the battery but not sure (will check the maint. records). After spending 30 mins on the intersection it finally started. Made it home luckily but I don't trust the car now.
It all depends on your compression ratio.
High compression ratio needs high octane so as not to pre-detonate. Using a lower octane fuel shouldn't have anything to do with getting the car started as I understand it. I think you have some other issues. What were the other symptoms of 'not starting'?
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
Assuming the engine is stock, you should use whatever the manual specifies. My '85 Carrera will run just fine on 87 octane. I have pumped 93.5 before and couldn't tell the difference in either power or mileage. I do get slightly lower mileage with the 10% ethanol fuels that are so common anymore.
Sounds to me like your problem is more mechanical in nature. I'd check the basics - filters, plugs, hoses, pump, dist cap and rotor, wires - all the tune-up stuff. Good luck.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
Friend of Warren
Octane of gas doesn't have anything to do with a start/no start condition.
Kurt V No more Porsches, but a revolving number of motorcycles. |
+1 to all the above , regular ignites easier thats why it detonates prematurely .It can be set off by hot spark plug tips.Some low comp. antique engines can,t run on modern gas because the octane is too high.
76-911s 80-911sc Regards Lester |
Skunk works
Our "regular" fuel in Aus is 92 and high octane is 98 I run 98 octane. just replaced plugs, dizzy cap, etc etc etc and car runs like a dream
964 RS-4 |
Your 76 911 engine is designed for regular so why not find a better way to waste your money.
Hi octane fuel doesn't have more "balls", it's just ordinary fuel with additives to make it not ignite so easily.
Octane shouldn't impact starting on a 911.
How much lower do you think any other antique engine's compression ratios were? Mine was designed for fuel with an octane rating of 25 to 30, (before tetra ethyl lead was introduced) if I recall correctly. Regards, Jerry Kroeger
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
Targa, Panamera Turbo
I studied this years ago with an 86 Camry. I actually logged the miles driven and the money sent comparing 93 and 89 for an entire year. On the average, I got an extra 4 mpg more with the 93 but the price difference made it a perfect wash. I did not do a performance study - only mpg.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Czar of C.R.A.P.
I may be wrong but would a car with knock sensors take advantage of the higher octane by advancing the timing and possibly getting better performance and mileage. Just a thought. One thing about premium in many places is an ethanol blend. The octane is higher but the energy output is lower unless the car is modified. In Nebraska we have both ethanol enhanced premium sometimes called super and the non-alcohol premium. Usually the cheap places have the ethanol and places like BP have the real premium fuel.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
try this and you can't go wrong....
Pull the relay under your seat for the fuel pump, pull it apart..i.e. pull the contact section out so you can look at it. look in the bottom of the plastic cover and fold a match book cover once, not the whole thing but a piece about the size of the square cover 1"X1" or so, fold it over once place in bottom of plastic cover and install the relay again, you will note that the circuit board is not centered so try to make sure that the paper is in a position to fold as you slide it in. think of it like this the V is the paper, dashes are the circuit board with the offset toward the bottom of the V V---] hope this helped, after fuel pumps and relay replacement and being stranded a few times. I worked with my old relay and got it to work this way. still to this day it works. |
i get about 1-1.5 better millege w/reg. Less additives = more fuel.
i don't recommend reg.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
So your saying my 80 SC could run on 87 instead of 91? I just put the Prem gas thinking it was better for the car
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Frank
I would stick with the Prem. With all the noise back there we wouldn't hear the pre. ign.
----------------------------- Ernie 81 SC |
MAGA
Nothing but 87 in my '79 SC. I think it has lower compression than the later SC's though.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Prem is it is then and you are right noisy but fun
Skunk works
2. i think i can affort the whole $2 extra it cost to fill a tank with premium.
964 RS-4 |
Designer King
We need more info from you on symptoms regarding your no start condition. The octane rating most likely has no bearing on this.
I have to disagree w/ the previous comment on leaded fuel. 911 engines don't require the properties of lead like many others of that era did. The octane rating is just achieved using other materials today.Your 2.7 if stock should do OK on the specified octane, provided you haven't changed the compression, timing, etc. Having said that, older engines sometimes require a little extra octane level due to factors like engine wear and carbon buildup. If you want to be sure, go from 87 to 89, but there's no reason to go higher.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
