Heating after throttle bodies
Has anyone any experience or ideas for heating improvements for a 911 3.2c 1984. I have installed throttle bodies which means the engine fan to assist in airflow through the heat exchangers doesnt fit.
Has anyone had this experience and managed to give the heating a bit of a boost, or is there any aftermarket products in general that bring the heating into the 21st century... Many thanks
Pete Porsche, there is no substitute! 911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv |
Administrator
Does the car already have the kick panel blowers?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Mine is an early car and doesn't have kick blowers. Can they be retrofitted?
If you think you need the fan can't you mount it further back in the engine compartment? Get creative with the mounting bracket maybe? The heater hose being flexible gives you different options if you can come up with a alternate mount for the OEM fan.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
thats probably going to be the only way forward. I'll have to modify the triangular blanking plate as it interferes with the twin spark distributor.
Is it possible to retrofit the kick fans? Also has anyone ever had any experience fitting an after market heater. I have read about Webasco petrol heaters that are mad for th early 911's?
