Wider plug gap with Bosch CD on '69 T?
Is there anything to gain by increasing the stock spark plug gap with a factory 3-pin Bosch CD box?
Engine is a stock '69 T with Webers in a '68 911. Replaced the Marelli with a Bosch distributor and added the CD. I'm not having any running issues, just wondering if there's any reason to go larger than stock.
Thanks,
Mike
Mike
'68 911 # 11830241
Old 02-04-2007, 08:11 AM
Bill Verburg's Avatar
If'n it ain't broke, don't fix it.
there are conditions where a wider plug gap is useful
Bill Verburg
Old 02-04-2007, 09:55 AM
Early_S_Man's Avatar
Porsche Crest
Mike, the factory-recommended plugs for your engine were the very expensive, old Bosch Platinum W235P21s, and they had fixed gaps of 0.24". I don't know of anyone recommending those plugs these days.
When other plugs such as NGK BP6ES, or the newer V-Power BP6EY are used, most people have used 0.028" - 0.032" gaps with great success! Those are the plugs and gap that I would suggest you use.
Here is an NGK booklet that may be helpful:
http://www.ngksparkplugs.com/docs/tech/Racing_Spark_Plugs_Performance_Applications.pdf
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-04-2007, 10:27 AM
