Poll: What weight oil do you use?
Poll Options
Regardless of synthetic or not, what viscosity oil do you currently use in your Porsche? Also, what's the coldest temperature you normally start your car in?
I currently am running Mobil 1 0w40 which was that the dealer had put in, but I plan on changing to an oil with higher levels of Zn and P, yet undecided. I would easily run a 20w50 year round if it wasn't for the fact that I do drive the car in the winter and typically I have cold starts lower than 32F, but no colder than 0F.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 02-27-2007, 07:17 AM
SCWDP911's Avatar
Charles, I posted on your other thread about oil a few minutes ago, but thought I would do th same here. I currently use Castol 20w50, but I am coming up on first oil change as the new owner on the 83 cab. I am near Memphis, TN, and we can get an occasional cold snap here that puts us in sub 32 deg temps, but very rarely below 0. Based on your post here, I am kind of curious if that is the break in temp I should be considering in cold-starts? my car is an almost daily driver.
Thanks,
Shane
Shane
- 1984 928S
Old 02-27-2007, 07:43 AM
20w50 is good up to 32F. A syn 20w50 technically could go even lower.
I'm holding off on making recommendations on oil for now because of the fact that so many oil companies are reformulating new SM oils, like Mobil's changing of a proven product like the 15w50. Makes you wonder what they are thinking...
I'm ordering more sampling bottles today so I can retest a few oils, just in case things have changed since I did my testing last year.
Charles Navarro
Old 02-27-2007, 08:10 AM
Somatic Negative Optimist
Gunter's Avatar
Pretty relative because it really depends a lot on where you live re: temperature.
I use mostly 15W40 Dino oil because I like the specs for Diesel application (High pressure and temps)
15W40 Dino in Spring and Fall when cooler,
20W50 Dino in the hot summer months.
I would NOT recommend 20W50 when the temp is approaching the freezing point.
I like Dino over Synth. on my SC 3.0
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-27-2007, 10:12 AM
I live in Louisiana, not cold here...maybe 32 once or twice.
Really hot and humid in the summer though 100+ with 70%
humidity. I had been running Redline 20/50 I've switched to
Mobil One 20/50 and am thinking about changing to the
Mobil One V-Twin. Do you know if Mobil is changing that oil ?
I'd like to use a very good synthetic and as far as I can tell
the V-Twin Mobil One is one of if not the best.... and really
expensive !! I thought RedLine was pricey !
Chuck
Old 02-27-2007, 10:20 AM
No, it appears they are going to leave the Mobil 1 V-Twin 20w50 at an api SG. I will also get a bottle of the 10w40 motorcyle mobil 1 to test, but it should be about the same.
The cheapest place I have found the M1 V-Twin is at Elite Etc.
http://www.eliteetc.com/mo1v20sin.html
Charles Navarro
Old 02-27-2007, 10:31 AM
Mahler9th's Avatar
Still running Mobil 1 15w-50 Extended Performance out here in CA. This is in a racing engine. A bunch of us are using it... so far no problems. I have about 60 quarts on hand in 5 qt. containers, and mt buddy has a 55 gallon drum. I guess we need to find out how much zddp it has. Charles, when is the last time you tested Mobil 1 15-50 Extended Performance? I couldn't find any dates or lot numbers on your list.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-27-2007, 10:44 AM
Here is a sample taken and tested 2/20 of the new SM M1 15w50 vs the levels found in the SL formulation of 1315 ppm of P and 1428 ppm of Zn.
Mobil 1 V-Twin 20w50, which is an API SG, has 1329 ppm of P and 1949 ppm of Zn.
Charles Navarro
Old 02-27-2007, 10:55 AM
Charles Navarro
Old 02-27-2007, 10:57 AM
Charles,
Please let us know what the P and Zn levels are for Mobil1 0W-40. I use it for my other vehicles too.
Thanks for all the great info!
Old 02-27-2007, 11:01 AM
Man, is there a market for restoring Zn & P levels to engine oils and it's now!
Any takers?
Old 02-27-2007, 11:05 AM
I've run 20W50 dino (almost all GTX) for 160K miles on an '85 which is daily driver in N. Cal.
I'm looking to switch to a synth like 15W50 Pennzoil Plat. or for winter, 5W40 Rotella-T. Both appear to be based on Shell's Grp III HXVI basestock, Helix Ultra.* Of course I'm concerned about Zn/Phos (ZDP) levels and how adding boron might help. Adding GM ESO seems like a bad idea as it requires a lot (like 1qt/tank) to bring up the ZDP from 900ppm to ~1100 (Atleast according to my cals.)
Others I have considered are M1 15w50 (but Charles has bad news on the ZDP) and Castrol Syntec 20W50 (but not 5W50 as I think it's low ZDP). I did not do VOA but can cite references on Syntec.
* I have a 2005 Ford Duratec engine (porsche design) using 5W20 and recently switched from Motorcraft blend at 18K miles to Penzoil Plat. synth (HXVI basestock). I have a closed loop 40 mile highway course with MPG monitor and found astonishing 5% better gas mileage using PP synth over MC blend.
NOTE: I don't believe synth has better gas mileage for same weight so I'm skeptical. I'll evaluate 5000 mile MPG when complete OCI but on a trip to SanDiego +5% seemed to hold up. I can't explain this but could justify switch to synth if I could get +5% improvement in the 911 even if requires lighter weight.
Old 02-27-2007, 11:22 AM
Designer King
Paulporsche's Avatar
Mobil 1 15W50 in temps ranging from -5 to 35C (approx 24 to 95F)
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-27-2007, 11:45 AM
chrisp's Avatar
The thinnest possible while still maintaining proper oil pressure. Weight of oil changes with running temps which are affected by ambient temps.
'83 SC
Old 02-27-2007, 12:20 PM
holtjv's Avatar
I was running 20/50 Valvoline with sub 30 degree starts and it was very balky and slow to start (2x). Switched to M1 15/50 EP and starts faster and on one crank.
Oh, and it's gotten warmer, too. So I have no idea how much the oil change contributed.
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 02-27-2007, 01:10 PM
3.4 Bigger is better
88-diamondblue's Avatar
Valvoline VR-1 20-50, switching to Brad-Penn 20-50 coldest starts are 40 degrees. Driven 6 months of the year.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 02-27-2007, 09:51 PM
5w/ 50 Fuchs Synthetic
Daytime temperatures often 100-120 and summer nights not below 80 F.
Old 02-28-2007, 12:33 AM
Where in the world do you buy that oil... never seen it before?
Charles Navarro
Old 02-28-2007, 10:05 AM
Charles,
Regarding your analysis of Mobil1 15W 50 (EP), I see that Mobil has brought back the old 15W-50 (gray cap now) claiming it has the antiwear protection we're looking for. Maybe you could take a look at it.
Old 02-28-2007, 05:27 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
So I can switch to Mobile1 15-50 in my '83 SC 3.0??? I would love to just have to buy one oil for the cars... I already use the 15-50 on the 964.
Have not had to change the oil in the SC... but for when the time comes...
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-28-2007, 06:22 PM
