-   -   RSR Conversion - Part 1 - The discovery (http://forums.pelicanparts.com/porsche-911-technical-forum/328824-rsr-conversion-part-1-discovery.html)
wachuko 10-01-2007 12:19 PM
Woohooo!!! Parts from GT Racing arrived at Orlando... delivery to my house scheduled for this Wednesday, Oct 3rd
wachuko 10-03-2007 02:43 PM
Parts arrived today:
New fan, housing, alternator:
http://forums.rennlist.com/upload/new_fan_housing.jpg
Rear qtr panels and bumper:
http://forums.rennlist.com/upload/rear_qtr_panel_1.jpg
http://forums.rennlist.com/upload/rear_qtr_panel_2.jpg
No brackets on the rear bumper... hummm, more fabrication required...
http://forums.rennlist.com/upload/rear_qtr_panel_3.jpg
wachuko 10-03-2007 04:13 PM
Mandatory duct-tape install photos :)
http://forums.rennlist.com/upload/rear_qtr_panel_4.jpg
http://forums.rennlist.com/upload/rear_qtr_panel_5.jpg
http://forums.rennlist.com/upload/rear_qtr_panel_6.jpg
http://forums.rennlist.com/upload/rear_qtr_panel_7.jpg
It will take some serious rubber to fill those wells...
http://forums.rennlist.com/upload/rear_qtr_panel_8.jpg
SmileWavy
Tom '74 911 10-03-2007 04:25 PM
You are a brave man! Kudos!
Tom
Matt_West 10-03-2007 08:30 PM
Dang you provide dangerous inspiration. Great courage.
village idiot 10-04-2007 01:22 AM
You barely have enough room for both those cars in there. Time to "renovate" the garage:D
JeremyD 10-04-2007 05:39 AM
Thats awesome!
wachuko 10-04-2007 05:59 AM
I wish I could... That is one of my dreams, building a custom home with a decent 40'x60' workshop... :D maybe someday... For now this three-car garage will have to do... I just move them out when working on the car... and a friend is kind enough to let me store one of the cars in his garage when the space is needed for long periods of time...
When we got this house I had them add 2' to the garage to allow for the closet and working bench you see in the back. What I forgot to ask for was a higher ceiling
http://forums.pelicanparts.com/suppo...leys/splat.gif
That would have allowed me to put in a two-post lift... nothing I can do now...
PcarPhil 10-04-2007 06:04 AM
Man this is an interesting thread! Those rear flares make my 11" turbo flares look tiny...
Forgive me if you've already answered this but what are you planning on running for wheels/tires and what do you have planned for an engine?
Keep up the progress updates!
wachuko 10-04-2007 06:16 AM
I am scare sh#@$%less on the amount of cutting that is required for the rear panels... time to search in the folder for those photos of others who have done it... I don't want to cut more than is needed and even will try to leave as much original metal as possible...
from the initial looks of the FG panels it looks like I have to remove the rear side glass and cut into the window frame :eek: I don't think I will do that.. I rather cut the FG to where it touches the lower part of the window side and glue it there...
I need to do my homework now before I make the first cut...
SmileWavy
wachuko 10-04-2007 06:21 AM
Search for wheels here:
RSR with vented flairs-What wheels are you using??
Looks like I will end up with something like these:
http://forums.pelicanparts.com/uploa...1171984015.jpg
Engine: not too many changes... only plan to put some PMO 46 carbs to give it a better look... when the time comes, a rebuild but not planning on making any changes from the stock components unless is for reliability reasons...
PcarPhil 10-04-2007 06:34 AM
You're probably already aware of this but please keep in mind:
-increased overall wheel/tire weight that is unsprung weight.
-increased overall tire diameter and it's affect on gearing.
I believe the car in the pic above has a 3.6 engine which of course helps overcome the issues mentioned above! Those big meats might be a bit much for a stock 3.0 and stock 915 trans.
Edit: Regardless...you've got a very cool project in the works...
wachuko 10-04-2007 07:48 AM
Just a few reference photos of the fender install from other folks here...
Please free to add more from your project or photos you have come across SmileWavy
From JohnnyB:
http://forums.pelicanparts.com/uploa...1191509129.jpg
http://forums.pelicanparts.com/uploa...1191509164.jpg
From Win Van den Berg RSR (he has been a great source of information for my project, what a guy!!) :
http://forums.pelicanparts.com/uploa...1191509314.jpg
From M325ix
http://forums.pelicanparts.com/uploa...1191509622.jpg
http://forums.pelicanparts.com/uploa...1191509645.jpg
Brother 10-04-2007 08:34 AM
What did you need the new fan and housing for?
wachuko 10-04-2007 08:54 AM
A few weeks back I started to hear like the fan was touching the housing... I thought it was the alternator bearings that had gone bad. I removed everything and took the alternator to a repair shop... bearings were fine. After looking again at the fan housing I noticed several cracks... rather than trying to fix those (read a few post here that welding the magnesium housing was going to be a pita) I decided to order a new one.
Porsche no longer makes the housing so I ended up buying a replacement. These come in Aluminum now...
BTW, I will be soooo happy when I remove all that CIS stuff and replace it with a beautiful set of PMO carburetors... but first I need to finish all the body work, and get the wheels/tire combo...
http://forums.rennlist.com/upload/alt_reb1.jpg
http://forums.rennlist.com/upload/alt_reb2.jpg
http://forums.rennlist.com/upload/alt_reb3.jpg
http://forums.rennlist.com/upload/alt_reb4.jpg
http://forums.rennlist.com/upload/alt_reb5.jpg
http://forums.rennlist.com/upload/alt_reb6.jpg
You can see one of the cracks it in this photo, in the lower left side...
http://forums.rennlist.com/upload/alt_reb7.jpg
I had to do the new fan housing, new 11 Blade Alternator Fan (also in aluminum), and new 90amp alternator (because I needed the updated alternator to work with all the other parts, housing is for an 84 and requires this alternator)... I also ordered the nice looking strap from Rennline (via Pelican Parts) to go with the changes.
Now I only need to decide what color I will paint them (maybe best to powdercoat them since there are all new.... hummm...)
So... I have a fine working alternator if anyone is in need for one...
DW SD 10-04-2007 04:20 PM
When do we move past "Part 1 - The Discovery"??
I move for starting Part 2!
Careful with the oversized bodywork and flares and large wheels combining that with limited power to back it up. Don't want to be "all show and no go".
Cool project.
wachuko 10-05-2007 06:50 AM
Cool project.
Done! SmileWavy
RSR Conversion - Part 2 - The build
wachuko 10-08-2007 10:48 AM
Since I posted the alternator stuff on this one... all other body updates will be done in the second thread started...
Used Tractor Supply paint... very thick/strong paint...
Nothing seems to be straight forward... rear bolts on the new alternator are different... so now I have to go out and get the correct size nuts...
http://forums.rennlist.com/upload/dsc04143_medium.jpg
http://forums.rennlist.com/upload/dsc04144_medium.jpg
http://forums.rennlist.com/upload/dsc04145_medium.jpg
http://forums.rennlist.com/upload/dsc04146_medium.jpg
http://forums.rennlist.com/upload/dsc04147_medium.jpg
http://forums.rennlist.com/upload/dsc04148_medium.jpg
That is it for this thread... I should start bolting the rear qtr panels tonight to then mark and start cutting the metal... :eek:
Determined 01-06-2016 07:57 PM
subscribe
wachuko 01-06-2016 08:01 PM
Originally Posted by Determined (Post 8946862)
subscribe
Sorry to say... Car was finished, sold to my friend that helped me finish it...and he sold it a few months ago :mad:
I think that it went to Hawaii...
