Engine Stand Adapter Bolt Size
After searching here I found a size of 10 x 1.5 as the bolt size needed to attach the u-shaped adapter I got today from Pelican to my engine stand. Can someone confirm this size and also tell me what length is best?
Thanks. Tom |
Author of "101 Projects"
The case should have studs sticking out of it that are 10 x 1.5. These are what you place inside the stand. You can also use bolts too, but you will eventually need to find and replace the studs, so you might as well use them...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne.
Tom |
