palle7688's Avatar
Cool brake ducting, with pics.
Thought I would share this.
Made from leftover 3" galvanized pipe normally used for my house rain gutter drain. Cut to fit.
You have to remove the galvanizing in order to weld it.
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 02-05-2007, 07:36 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Very nice!
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 02-05-2007, 07:44 PM
Friends of Warren
911teo's Avatar
I love it!
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 02-06-2007, 05:32 AM
19 years and 17k posts...
azasadny's Avatar
Great work!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-06-2007, 05:42 AM
IROC's Avatar
I like your use of the tubing around the a-arm. I need to do something like that in the next month. How did you secure the tubing to the a-arm? I'd like to see some pics of the completed routing if you have a chance.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-06-2007, 06:11 AM
cycling has-been
bkreigsr's Avatar
in a word, yes, cool
pic of finished front valance please, and the completed ducting?
Bill K
Old 02-06-2007, 07:22 AM
Bye, Bye.
Scooter's Avatar
More pics of your car, please!
Elvis has left the building.
Old 02-06-2007, 08:21 AM
jaydubya's Avatar
Great work! The tube over the a-arm is like the pieces that Smart Racing sells, only much cheaper!
I'd like to see th hose routing too. I have the Smart Racing pieces, which use 2.5" diameter hose, and I can barely get those routed properly between the a-arm, swaybar droplink, brake line, etc. to line up with the inlet for the backing plate... Seems like 3" tubing would be nearly impossible to route through there.
Cheers,
JEff
'82 911SC racecar
'05 WRX STi
Old 02-06-2007, 08:22 AM
randywebb's Avatar
the tube is small so don't expect miracles...
very clean looking tho
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-06-2007, 08:34 AM
palle7688's Avatar
I'm so sorry but I can't get to my beloved car for some time. I'm working abroad at the moment. This gave me the time to post these pics:-)
No pictures of finished valance on car, except the ones already shown.
Screen hold in place with bodysealant only.
No pictures of ducting but it runs from inlettube to the tube on A-arm and from tube on A-arm over A-arm and behind swaybar link to the fabbed rotor backplate. I'm using 3" hose but it barely clears and get worn after a while. I've tried to clearify with photoshop. Please, bare with me, I'm a novice in this.
This was done spring 2005. One thing I had to mod was the tube on the rotor backplate. The thickness of the tube is to small to really thighten the hose clamp so the hose bacame loose when the wheels turn. I cut a piece of sheetmetal app. 1/2" wide and long enough of fit inside tube when rolled. I then drilled some holes in the tube and spotwelded the rolled sheetmetal in place to reinforce tube. Works perfectly.
The cutout in the tubes on the A-arm is closed with some sheetmetal or a piece of tube cut in half like a "C". Holds in place with tiewraps or the clamps for hose. The safety wire shown in picture on A-arm tube is just for trial fit. This tube a clamped against the part of A-arms where torsionbar is.
Old 02-06-2007, 09:06 AM
Nice job, but a quick comment. The wire grill is going to impose some air flow restriction. If you could disassemble the grill wires and group them together, you'd see how much of the passage it blocks. For street driving, leave as is since you're rarely going to overtax the factory brakes. For the track, make the grillwork removeable. Just MHO.
Sherwood
Old 02-06-2007, 10:52 AM
palle7688's Avatar
yeah, I know, but it was I had. But it makes it a bit stealthier.
In the last pic in first post the grille is not installed.
If it ever becomes loose I'll replace it with bigger mesh grille.
Old 02-06-2007, 11:37 AM
palle7688's Avatar
Any suggestions on how to make a removeable grille???????
Old 02-06-2007, 11:38 AM
Zeke's Avatar
I don't know, you seem to be doing pretty darn good on your own.
I think Sherwood has a point, but it's on the track that you need a little protection, methinks. I would surmise that most rocks would get hung up in the duct work before getting into the rotors. Maybe all you need is a more open and finer weave on the wire to let in the maximum amount of air.
For a removable screen, I'd try to make a small flange or series of tabs for the mesh to rest against. To hold in place, just some srews and washers. Real pretty would be a bezel. Maybe there's something from some kind of dash board or other source. Check those aircraft supply places.
Old 02-06-2007, 01:08 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Agreed that it does not need to be removable. Just pick a screening that has quite large openings. Track debris can indeed get into the rotors. More of a concern is track rubber, than rocks.
Take a look at what I did here
new valence and cooling ducts
It's by no means the perfect solution. I still have to install the receiving ducts and the hose, and remove the 964 scoops in lieu of backing plates.
Kevin L
'86 Carrera "Larry"
Old 02-06-2007, 03:18 PM
MBruns for President
JeremyD's Avatar
Yeah - mine are similiar to Kevin's - but with a similiar modification
to add some more fresh air to the brakes and carrera oil cooler.
Looks like a stock carrera - Stainless Steel mesh epoxied to the inside of the housing
APC driving light mounted to the inside
Lights on
with the flash to highlight the guts
Old 02-06-2007, 03:34 PM
cycling has-been
bkreigsr's Avatar
anyone think the rotation of the disks will create a negative pressure down the inlet tube thereby eliminating the concern that the inlet with screen will suffer because of the aero effect?
Bill K
Old 02-08-2007, 11:35 AM
I don't. Airflow hits a spinning wall. Where does the air go then? Probably stalls. If you want to ensure positive air flow, find someplace to install an inline blower in each hose. Here's one from Detroit Marine:
I'd recommend a water spray system too, but I'd save that for serious brake cooling.
Sherwood
SeineSystems. com
Old 02-08-2007, 12:47 PM
palle what kind of wheels are those. They are awsome! Very cool braking ducts also. Looks like somthing i would do
Old 02-08-2007, 01:55 PM
len911's Avatar
For the benefit of all of you, and not stealing the thread, I'll show you the setup on my 74. I also made the A-arm tube and in addition, made my custom backing and blocking plates since I use Wildwood rotors. Pictures are also included showing hose routing. I use a coarse grille on an RSR bumper and I have tested it with a leaf blower to make sure there is enough air flow into the rotors. Enjoy... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 02-08-2007, 03:30 PM
