Door stay replacement
Hi -
I'm replacing a door stay and can't get a socket in there to tighten the new bolts - the outside sheetmetal is in the way at the very top and very bottom of the opening. I've managed to get them finger tight, but am stuck after that. Is it a crime to dremmel (cut) the sheet metal out just enough to fit a socket in there? Is there another trick to getting these suckers installed? Also - Is it fairly standard practice to grind down the (2) bumps on the new stay so the door swings a little easier? Thanks, Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Throw it on the ground!
Funny you should ask. My relatively new door stay started making a clicking noise yesterday. I thought it was the cold weather but on closer inspection, the bolts had come loose. I don't remember it being as tight an area when I originally installed them, but without a socket available in the parking lot, I was able to tighten them easily with the 10mm wrench in the tool kit as you can angle them better than a socket.
I would not grind down the high spots. You will find the new stays very stiff at first but they will loosen up very quickly. Good luck!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
You mean they're *not* supposed to make a click as they pass over the bumps? Mine make a very loud click at two positions. The stay was recently replaced (before I bought the car)...
Chris Kantarjiev 73.5 911T Targa and the rest: 66 TR4A 69 FJ40 70 GT6+ 00 2.5RS |
They will be very stiff at first and may even click at first until the break in but it will go away. IMPORTANT: Check to make sure they are not clicking because the door frame they are bolted into has failed. If it has failed, you may need a weld repair or the door stay reinforceemnt kit sold here (Part #PEL-PP911167)
The loud click that you hear is probably the metal on your door flexing. This is a very common problem especially on drivers side doors (generally used more often than passenger doors) and should be fixed with a reinforcement kit before the damage is beyond repair.
if anyone needs
i just took off two good door stays from a pair of 72 doors |
Well, I checked at lunch. Both bolts were quite loose. That was easy to fix (they have a slot as well as hex head). Looks like I have the required 1-3/4" spacing, so I'll open up the door and install a reinforcement kit ... some day.
Thanks!
Thanks, Tom
I'd go in there with a crowfoot wrench, myself.
What you need is a 1/4 inch socket wrench, small head, 10mm socket and the key - small extension with a universal joint - makes this much easier and no need to cut out anything to get to the nuts.
Jeff |
I purused some older threads on this and saw one photo where someone used allen head bolts. I may try to locate some that will fit - then I'd have no problems at all. If that doesn't work, I may end up dremeling a slot for a flat head screwdriver. At least I've got options I guess! Thanks, Tom
I replaced both of my stays a month or so ago and don't recall having this problem. I used a 1/4" deep socket. No dremeling required.
Good luck
96 993 coupe 88 911 cab (gone, but not forgotten) |
try 6 pt. & 12 pt. - deep & shallow & a high quality brand that might be narrower than a cheaper one
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I replaced mine in October. My kit, from our host, came with allen bolts. Even if it had come with standard hex bolts, my '87 has plenty of clearance around them for a socket.
Silver '87 Targa |
Sorry couldn't be more help -Jeff
Jeff |
I'm not certain if the door has ever been repaired - or even seriously damaged for that matter. I can't see anything obvious, but it certainly could be bent and I just don't know how to recognize what I'm looking at. The other door and stay look very similar - I've currently got both doors apart to put on RS panels, so it's easy to compare. Hopefully I can round up some allen head bolts today and be done w/it. Thanks again, Tom
My new door stay came with allen bolts as described above which made that a breeze since the slim allen wrench dives in there with no issue. Perhaps try to get the right bolts. I used the reinforcement kit sold by pelican with success (which comes with allen bolts as well).
My new stay was very stiff at first but broke in after about a week or two. The lube provided with the new stay seemed to work as designed. |
SCHoward is correct. Note the photos of my '74 in the link below with regular bolts and allen bolts. It is tight. Get some similarly sized allen bolts.
Problem with door hinges "Clicking"
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
