beamonk's Avatar
Send a message via AIM to beamonk
993 brake conversion/Banjo's necessary?
I am about to start on my 993 conversion on my SC. Do I need to use banjo fittings on the front 993 calipers? I couldn't find the thread that addressed this before. Can I use the banjo's from the earlier calipers that I have "in stock"?
Thanks,
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 02-08-2007, 11:09 AM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
i didnt use a banjo on mine. i went to napa and purchased several different lengths of threaded brake line and made mine. i think the fronts took a 8 or 10" piece and the rears were also the same. i just came out of the caliper and made a 90 around 1" out. i think i copied one of the other pics i had seen on here. i just made sure to run it up to the factory tab on the strut to secure it before adding the braided line....
Old 02-08-2007, 01:00 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Ditto what Brent said. No banjos necessary. Just a regular M10 x 1.0 fitting with bubble flare.
Kevin L
'86 Carrera "Larry"
Old 02-08-2007, 01:15 PM
I didn't have to make mine. I used the 928 Stainless steel lines with Banjo bolt. The kit from ***************** has the lines and comes with banjo bolt (M10), and seal washers - all in one kit, nice. I didn't have the tabs on my struts (RSR).
Old 02-08-2007, 02:57 PM
KTL KTL is offline
Schleprock
KTL's Avatar
http://www.*****************.com/product_p/por1200.htm
That does look like a nice solution! Thanks for sharing the info. Not too pricey and makes for an easy bolt-on solution. Only downside I see is having to make sure some spare crush washers are on hand when doing brake work. But nothing an order to an industrial supply place couldn't solve........
Thanks!
Kevin L
'86 Carrera "Larry"
Old 02-09-2007, 08:12 AM
North Coast Cab's Avatar
John, go to Napa and buy 2-1' long M10x1.0 bubble flare lines for $4/ea. They bend up perfect.
1985.5 944 GTS
Old 02-09-2007, 10:07 AM
