-   -   Project has finally started '71 911T (http://forums.pelicanparts.com/porsche-911-technical-forum/329435-project-has-finally-started-71-911t.html)
rothaus 02-08-2007 06:02 PM
Project '71 911T Update
Finally I started again on my '71 911T. Below are some pictures of the work I did so far.
I disassembled the sunroof and motor and all the hardware, and I'm thinking welding the sunroof part in. I would cut out the sheet metal which is on the inside so I can install a normal head liner. Did anyone do a conversion like this ? and is there anything I need to know?
I try to avoid any leak problems later, and since I want to build this one for autocross, I don't need the sunroof.
Thanks for any feedback !
http://forums.pelicanparts.com/uploa...1170989900.jpg
http://forums.pelicanparts.com/uploa...1170989928.jpg
http://forums.pelicanparts.com/uploa...1170989952.jpg
http://forums.pelicanparts.com/uploa...1170989973.jpg
http://forums.pelicanparts.com/uploa...1170989994.jpg
http://forums.pelicanparts.com/uploa...1170990015.jpg
http://www.pelicanparts.com/support/smileys/wat6.gif
Cheers
Fishcop 02-08-2007 06:14 PM
Nice!
Looks like you're petty handy?
Welcome to the board...
Jgordon 02-08-2007 06:41 PM
Dude, I change my own oil and mess with the valves. I'M handy. This guy is "qualified."
Nice work - welcome.
rothaus 02-09-2007 08:24 AM
Thanks for the reply !
I will post more pictures as I progress.
david914 02-09-2007 08:32 AM
Ditto on "qualified"! Keep the pics coming! Would love to know what the particulars on your project are (engine, suspension, flares, etc.)? Also, what part of Virginia are you in? I'm in the Richmond area.
Jays72T 02-09-2007 08:37 AM
Nice work.
livi 02-09-2007 11:02 AM
Applauding restoration of a longhood!!
Good work and welcome aboard!
I love the color schemes for the pre 74 cars and yours is no exception. What it is called ?
therotman 02-09-2007 11:08 AM
Nice Garage! What's the black car?
The flower vase gives the red one away
Jim Richards 02-09-2007 11:09 AM
Markus, that looks like Conda Green to me. :)
rothaus 02-09-2007 05:11 PM
The black one is my '90 Ford T-bird Supercoupe, still original.
http://www.pelicanparts.com/support/...s/beerchug.gif
Cheers
rothaus 02-09-2007 05:13 PM
You are right..... it's gona be green. Anyone knows what the green is called?
Jim Richards 02-09-2007 06:25 PM
It is Conda Green, paint code 2626 (color chart no. 222). This is a 1970 Porsche color.
rothaus 02-16-2007 05:04 PM
I'm in the Richmond area also...... Powhatan
Here some pictures from last weekend
http://forums.pelicanparts.com/uploa...1171677714.jpg
Cutting out the old
http://forums.pelicanparts.com/uploa...1171677729.jpg
Fitting and welding in the new.
I try to finish the front end this weekend......
Cheers
rothaus 02-19-2007 08:29 AM
Since last posting I had some progress. The front bottom parts is complete, see pictures below.
http://forums.pelicanparts.com/uploa...1171905994.jpg http://forums.pelicanparts.com/uploa...1171906004.jpg http://forums.pelicanparts.com/uploa...1171906014.jpg http://forums.pelicanparts.com/uploa...1171906024.jpg http://forums.pelicanparts.com/uploa...1171906034.jpg http://forums.pelicanparts.com/uploa...1171906055.jpg http://forums.pelicanparts.com/uploa...1171906066.jpg
Next are the floor pan complete.
Porsche Doc 02-19-2007 09:37 AM
Looking Good Man! ;)
Keep up the good work!! :D
SmileWavy
BlueSideUp 02-19-2007 10:36 AM
This may be a dumb question but what kind of welder are you using?
Jim727 02-19-2007 11:11 AM
rothaus -
I also have a green '71. My color is Signal Green which, therefore, is The One True Green. Conda green is slightly brighter and has a bit more yellow in it. Can't really tell from the photo which you have, but most likely it's Conda. Signal Green was a factory special order color - I've been driving my car for almost 34 years and have only seen one other, so it's rather rare.
Edit to add link. Here 'tis:
http://forums.pelicanparts.com/porsche-911-technical-forum/316877-norcal-fun-runs.html
Jim
rothaus 02-19-2007 01:14 PM
I'm using a mig welder with shielding gas. See below.
http://www.hobartwelders.com/products/handler140.html
rothaus 02-19-2007 01:16 PM
Originally posted by Jim727
rothaus -
http://forums.pelicanparts.com/showthread.php?threadid=316877
Jim
Mine is the lighter green, Conda. I planned to make the car red, however, after some input and thinking, I decided to keep it the same color.
Cheers
rothaus 02-26-2007 02:47 PM
Update
After finishing the front bottom end, now it's time for the small painefull pieces.
http://forums.pelicanparts.com/uploa...1172533430.jpg
More bits and pieces
http://forums.pelicanparts.com/uploa...1172533464.jpg
This is the other side abd how it looked before.
http://forums.pelicanparts.com/uploa...1172533506.jpg
Piece after piece.
More to come.
Cheers
Engelberthttp://www.pelicanparts.com/support/...s/beerchug.gif
rennch 02-26-2007 02:57 PM
Englebert...I am doing the same rocker panel replacement, and it looks like I have to take a donor chunk slightly further back like you did. Did you document your process when you did it? I'd love to take a look.
Thanks!
rothaus 02-26-2007 04:58 PM
Thanks!
Hi,
I actually cut out the piece you see missing. and I welded it back in. I added a backing strip on the back. About a 3/8 wide piece of sheet metal. It helped to align the piece.
You have to be careful weling in the piece, just go slow and don't try to weld it all the way at the time, or it will pull in a dent.
Good luck.
http://forums.pelicanparts.com/uploa...1172541476.jpg
azasadny 02-26-2007 05:40 PM
Engelbert,
Great work there! Welcome aboard and thanks for the pics!
rennch 02-26-2007 06:19 PM
Englebert...Why did you cut it? Is it just easier to get to the rocker that way? Do you have any other pics of the rocker replacement? You can send anything you want to porscheparts@whirledmedia.com if you have a few.
Larry_Ratcliff 02-26-2007 06:44 PM
Wow nice looking work are you a body man by trade?
rothaus 02-27-2007 08:56 AM
The rocker panels go actually under the rear side panels, and they are welded on to the frame piece you can see on the image where the piece is cut out. I just welded it back in with a backing strip, since I had a gap from the cutting wheel. You have to be careful welding or the sheetmetal will deform.
I also had to add a piece between the rocker panel and the side panel since the side panel had thin material because of rust at that spot. :eek:
I normally cut out the rusted pieces and not only patch over it, as you can see.
I will post more pictures as I go along.
rothaus 03-10-2007 04:04 PM
Update on the Project 911T
Update !
Got the frame between the front hood and the wind shield done, and also the bottom corners of the windshield frame.
http://forums.pelicanparts.com/uploa...1173574785.jpg
http://forums.pelicanparts.com/uploa...1173574803.jpg
Cut out and replaced the section where the fender mounts.
http://forums.pelicanparts.com/uploa...1173574859.jpg
This weekend I cut out the rear portion of the floor pan.
http://forums.pelicanparts.com/uploa...1173574987.jpg
More to come
Cheers
Engelbert
gigem75 01-10-2008 05:11 PM
wow
lateapex911 01-11-2008 04:14 AM
what are you doing for corrosion protection and finishing in the hidden areas, such as behind the rockers?
SLO-BOB 01-11-2008 05:39 AM
Very impressive. What are your plans for the tub as far as coatings? After browsing the latest RSR thread, I would probably see about having the tub baked to get rid of all the goo and then coated for corrosion resistance. It would be reassuring that all that hard work would last as long as possible.
Kemo 05-16-2008 09:56 AM
any updates here? fantastic work
rothaus 05-16-2008 01:13 PM
Here is the last update
http://forums.pelicanparts.com/porsche-911-technical-forum/408420-update-my-project-911-a.html
Cheers
Engelbert
http://carmagic.us
