Carmagic.us
Finally I started again on my '71 911T. Below are some pictures of the work I did so far.
I disassembled the sunroof and motor and all the hardware, and I'm thinking welding the sunroof part in. I would cut out the sheet metal which is on the inside so I can install a normal head liner. Did anyone do a conversion like this ? and is there anything I need to know? I try to avoid any leak problems later, and since I want to build this one for autocross, I don't need the sunroof. Thanks for any feedback ! Cheers
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems Last edited by rothaus; 03-11-2007 at 06:48 AM.. |
Bird. It's the word...
Nice!
Looks like you're petty handy? Welcome to the board...
John Forcier Current: 68L 2.0 Hotrod - build underway |
Dude, I change my own oil and mess with the valves. I'M handy. This guy is "qualified."
Nice work - welcome.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Carmagic.us
Thanks for the reply !
I will post more pictures as I progress.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Ditto on "qualified"! Keep the pics coming! Would love to know what the particulars on your project are (engine, suspension, flares, etc.)? Also, what part of Virginia are you in? I'm in the Richmond area.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Nice work.
Jay '08 E350 Wagon '74 914 gone '72 T gone |
durn for'ner
Applauding restoration of a longhood!!
Good work and welcome aboard! I love the color schemes for the pre 74 cars and yours is no exception. What it is called ?
Markus Resident Fluffer Carrera '85 |
Nice Garage! What's the black car?
The flower vase gives the red one away |
Bandwidth AbUser
Jim R. |
Carmagic.us
Cheers
Carmagic.us
Bandwidth AbUser
It is Conda Green, paint code 2626 (color chart no. 222). This is a 1970 Porsche color.
Jim R. |
Carmagic.us
Here some pictures from last weekend Cutting out the old Fitting and welding in the new. I try to finish the front end this weekend...... Cheers
Carmagic.us
Since last posting I had some progress. The front bottom parts is complete, see pictures below.
![]() Next are the floor pan complete.
Looking Good Man!
Keep up the good work!! ![]()
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
This may be a dumb question but what kind of welder are you using?
-Jess |
Tree-Hugging Member
rothaus -
I also have a green '71. My color is Signal Green which, therefore, is The One True Green. Conda green is slightly brighter and has a bit more yellow in it. Can't really tell from the photo which you have, but most likely it's Conda. Signal Green was a factory special order color - I've been driving my car for almost 34 years and have only seen one other, so it's rather rare. Edit to add link. Here 'tis: NorCal fun runs Jim
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ Last edited by Jim727; 02-19-2007 at 12:20 PM.. |
Carmagic.us
http://www.hobartwelders.com/products/handler140.html
Carmagic.us
Cheers
Carmagic.us
Update
After finishing the front bottom end, now it's time for the small painefull pieces.
More bits and pieces This is the other side abd how it looked before. Piece after piece. More to come. Cheers Engelbert
