-   -   How to remove flag mirrors wiring? (http://forums.pelicanparts.com/porsche-911-technical-forum/329630-how-remove-flag-mirrors-wiring.html)
wachuko 02-10-2007 06:08 AM
Trying to remove the flag mirrors without cutting the wires. Is there a plug somewhere??:confused:
evill 02-10-2007 06:18 AM
Yes. The wiring harness is long. It runs through the door and into the front cowl section. You can see the harness in the door gap by the hinges when the door is open.The plugs are located up by the front hood hinges. It is a pretty tedious task to fish the wires through all the openings and grommets.
Ed
AirJose 02-10-2007 06:45 AM
Hi. There are two plugs, one small one inside the actual mirror but you have to remove the glass and then the mirror. Remove the three small screws to remove the motor piece to get access to it. The other larger one is inside the door frame. You have to pull from the inside of the door to get the wiring off. Hope this helps,
Jose
evill 02-10-2007 07:08 AM
Jose
Yes, there is one in the mirror too, I forgot.
Ed
khamul02 02-10-2007 08:20 AM
Here's some pics:
http://forums.pelicanparts.com/porsche-911-technical-forum/239808-flag-mirror-help.html
wachuko 02-10-2007 08:45 AM
Excellent. Thank you all!!
euro911sc 02-10-2007 09:41 AM
hehe.. I just cut mine and added a new water tight AMP connector... took me 5 minutes... ok maybe 10 ;)
-Michael
khamul02 02-10-2007 09:50 AM
Doing it the right way took less than 5 minutes :D
wachuko 02-12-2007 07:21 PM
No wonder people just cut the wires and are done with them... uff... I had to remove the pins from the plug to be able to pull the wires through the hole... Anyway, I labeled the plug with number and wrote down where each one goes. Mirrors finally out.
http://forums.pelicanparts.com/uploa...1171336845.jpg
http://forums.pelicanparts.com/uploa...1171336883.jpg
SmileWavy
