PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
How to remove flag mirrors wiring?
Trying to remove the flag mirrors without cutting the wires. Is there a plug somewhere??
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-10-2007, 06:08 AM
evill's Avatar
Yes. The wiring harness is long. It runs through the door and into the front cowl section. You can see the harness in the door gap by the hinges when the door is open.The plugs are located up by the front hood hinges. It is a pretty tedious task to fish the wires through all the openings and grommets.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 02-10-2007, 06:18 AM
Send a message via ICQ to AirJose
Hi. There are two plugs, one small one inside the actual mirror but you have to remove the glass and then the mirror. Remove the three small screws to remove the motor piece to get access to it. The other larger one is inside the door frame. You have to pull from the inside of the door to get the wiring off. Hope this helps,
Jose
Old 02-10-2007, 06:45 AM
evill's Avatar
Jose
Yes, there is one in the mirror too, I forgot.
Ed
Old 02-10-2007, 07:08 AM
khamul02's Avatar
Here's some pics:
Flag Mirror Help
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-10-2007, 08:20 AM
wachuko's Avatar
Excellent. Thank you all!!
Drive safe!
1967 - Porsche 912
Old 02-10-2007, 08:45 AM
Less brakes, more gas!
euro911sc's Avatar
hehe.. I just cut mine and added a new water tight AMP connector... took me 5 minutes... ok maybe 10
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-10-2007, 09:41 AM
khamul02's Avatar
Doing it the right way took less than 5 minutes
Tom Hutchinson
Old 02-10-2007, 09:50 AM
wachuko's Avatar
No wonder people just cut the wires and are done with them... uff... I had to remove the pins from the plug to be able to pull the wires through the hole... Anyway, I labeled the plug with number and wrote down where each one goes. Mirrors finally out.
Drive safe!
1967 - Porsche 912
Old 02-12-2007, 07:21 PM
