easy way to remove replace of turn signal
hello, all. would like to know if there is a trick in removing and installing turn signal on my 74. or, i just take a hack at it and go with the flow. do i need to worry about anything i.e. breaking or cracking something on steering column. please help. thanks in advance. SmileWavy
Remove horn button
Remove steering wheel Remove plastic column cover Remove turn signal switch. BTW, there is a thread here somewhere showing how to repair the high beam lowbeam problem by bending the contacts if thats your problem. Tried searching but I can't find it right now. |
yes, you're right i have that problem. thank you very much for the info and link. awesome!
de nada....
Welcome to the board....noobs have to post a pic of their car or no one will talk to you.....:D |
yes, i have been trying to post my car pics. it kept rejecting because it's more than 100k. so, i don't know how else to post it. i tried to save it as jpeg to lower the filesize. it's still more than 100k. any ideas? my current format is bmp. thanks.
http://members.rennlist.com/msucro1/relaykit.htm |
thank you fellow 74. i'm not home right now. but i'll check it out.
| All times are GMT -8. The time now is 04:24 PM. |
