easy way to remove replace of turn signal
hello, all. would like to know if there is a trick in removing and installing turn signal on my 74. or, i just take a hack at it and go with the flow. do i need to worry about anything i.e. breaking or cracking something on steering column. please help. thanks in advance.
Old 02-10-2007, 08:18 AM
Dueller's Avatar
Remove horn button
Remove steering wheel
Remove plastic column cover
Remove turn signal switch.
BTW, there is a thread here somewhere showing how to repair the high beam lowbeam problem by bending the contacts if thats your problem. Tried searching but I can't find it right now.
Old 02-10-2007, 08:45 AM
Dueller's Avatar
Found the link
turn signal switch quick fix pictures
Old 02-10-2007, 08:48 AM
yes, you're right i have that problem. thank you very much for the info and link. awesome!
Old 02-10-2007, 08:55 AM
Dueller's Avatar
de nada....
Welcome to the board....noobs have to post a pic of their car or no one will talk to you.....
Old 02-10-2007, 09:02 AM
yes, i have been trying to post my car pics. it kept rejecting because it's more than 100k. so, i don't know how else to post it. i tried to save it as jpeg to lower the filesize. it's still more than 100k. any ideas? my current format is bmp. thanks.
Old 02-10-2007, 09:10 AM
Bollweevil
If you haven't already done so, suggest you consider installing headlight relays to prevent the high/low beam problem once you have it fixed. The easiest way is to install the relay kit sold by Marcos Sucros which can be ordered / seen here:
http://members.rennlist.com/msucro1/relaykit.htm
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 02-10-2007, 12:01 PM
thank you fellow 74. i'm not home right now. but i'll check it out.
Old 02-10-2007, 12:09 PM
