MFI pump
Anybody know the weight of a MFI fuel pump? I tried to weigh one recently but the sucka was so heavy it bottomed out my scale...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I haven't got one to hand at the moment but I seem to remember that the last time I shipped one it was something like 8 kg.
Andy M&W 904 ... now gone GT-style 356C ... also gone |
Randy, my 0408 126 014 with mfi pulley and full of oil weights in at 17.5 lbs.
Mark Jung Bend, OR MFI Werks.com |
Randy,
My 009 is 15.5 with pully gear. I have a 019 I can check Monday. Bob |
Randy,
I dont have the parts available but I suspect you are trying to compare carbs to MFI. There are three considerations; mass, GC position and HP increase with MFI. The MFI system consists of: Pump Mount Mounting hardware Belt and cam pulley Extra sheet metal on LF of engine Extra weight of warm-up air system The high pressure steel fuel pipes, brackets and fuel injection nozzles Throttle bodies & Stacks there is significant difference between the 69-71 and 72-73 and later. Linkage & plumbing Now, the fuel filter console (69-73) and fuel pump (71-73) originally was in the rear. They can be repositioned to the front cross member and gas heater well. The fuel pump weight is the same Carb and MFI. The MFI filter console is heavier than a carb fuel filter. Moving all this to the front moves the CG down and forward. Carburetors consist of: Carbs (Weber or PMO Im ignoring 64 - mid 66 Solex)) Intake manifolds (911 Alu, 911 Mag, 906 tall Mag and various PMO aluminum configurations. Linkage & plumbing The various air filter configurations can be similar or dramatically different. The steel 69-70 are slightly heavier than the 71-73 plastic versions. The advantage of the steel is fire resistance but there is an issue with rust in the crankcase breather area. The advantage of the plastic is slightly lighter weight but far more susceptible to fire damage. Non-Factory air filter assemblies dont reduce the susceptibility for fire damage. They are relatively light weight and some claim HP increase. I can see some serious improvements in the aftermarket filters for MFI that carbs cant use. When discussing either carbs or MFI, having the systems working properly makes a HUGE difference. There is a lot of information about both here on Pelican. In general, MFI produces about 15 more HP, everything else the same. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Bandwidth AbUser
Randy, you're not gonna go off and swiss cheese one, are you?
Jim R. |
Constitutional Liberal
Speaking of MFI.
Check out this system I saw on a 2.5 racing engine built at Supertec. ![]() Is that really a five bladed fan? |
Thanks all. I'm not going to be drilling holes in any MFI pumps! I picked up a friend's pump a while back and the wt. really surprised me -- made me reflect back on its origins in diesel engines...
