-   -   Any tricks for removing motor mounts? (http://forums.pelicanparts.com/porsche-911-technical-forum/329768-any-tricks-removing-motor-mounts.html)
mthomas58 02-11-2007 03:36 AM
Thinking about changing out my 20 yr old motor and tranny mounts. Checked the motor mount mounts and, as suspected, they are frozen. Any tricks to loosen/ avoid breaking the cross-bar other than trying to soak with PB blaster?
It would be a real shame if I broke the cross-bar and had to replace with a Rennline Stainless, wouldn't it? :D
http://forums.pelicanparts.com/uploa...1171196977.jpg
charleskieffner 02-11-2007 05:01 AM
just did this. soak hell w/pb blaster for a week. its only 58FT LBS. torque from factory. pita to squirt bottom. just nail it w/long nozzle and squirt hell out of it. sprayed hell out of top, everyday waiting on pelican order to show up w/wevos.
take lil bolts, nut and lock washer and superglue lock washer to nut. let dry. wrap duck(quacky) tape around your middle finger, w sticky side out. attach nut w/lock washer to finger. place finger in correct position, and start to thread. do one side motor mt. at a time. 58 ft lbs big bolt. 17ft lbs lil bolts.
khamul02 02-11-2007 05:34 AM
I soaked (pb blaster) mine for 2 days and they came off pretty easily.
mthomas58 02-11-2007 07:26 AM
OK, soaked em overnight in PB Blaster and gave them a few taps with a hammer and a socket extension on the head of the bolt to help break the threads loose. I was able to move the bolts this AM!
Thanks!
