Throw it on the ground!
Any tricks for removing motor mounts?
Thinking about changing out my 20 yr old motor and tranny mounts. Checked the motor mount mounts and, as suspected, they are frozen. Any tricks to loosen/ avoid breaking the cross-bar other than trying to soak with PB blaster?
It would be a real shame if I broke the cross-bar and had to replace with a Rennline Stainless, wouldn't it?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 02-11-2007, 04:36 AM
charleskieffner's Avatar
just did this. soak hell w/pb blaster for a week. its only 58FT LBS. torque from factory. pita to squirt bottom. just nail it w/long nozzle and squirt hell out of it. sprayed hell out of top, everyday waiting on pelican order to show up w/wevos.
take lil bolts, nut and lock washer and superglue lock washer to nut. let dry. wrap duck(quacky) tape around your middle finger, w sticky side out. attach nut w/lock washer to finger. place finger in correct position, and start to thread. do one side motor mt. at a time. 58 ft lbs big bolt. 17ft lbs lil bolts.
Old 02-11-2007, 06:01 AM
khamul02's Avatar
I soaked (pb blaster) mine for 2 days and they came off pretty easily.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-11-2007, 06:34 AM
OK, soaked em overnight in PB Blaster and gave them a few taps with a hammer and a socket extension on the head of the bolt to help break the threads loose. I was able to move the bolts this AM!
Thanks!
Mark
1987 911 Coupe
Old 02-11-2007, 08:26 AM
