Highfield's Avatar
Tips on Carpet Fitting Needed
I finally got round to removing the sill sections (had to remove the seat support brackets as the carpet was fitted under them) and front map pockets - the last of the carpet removed that I intend to replace - i.e. from the B post forward.
Southbound have provided me with the carpet sections (black, and not perlon) and 500ml of glue.
Before I start, please give me your tips :-
- should I fully remove all traces of old glue, and if so, how ?
- should I strip and coat the floor and inner panels with POR ?
- should I glue around the carpet edges, or all over ?
- should I apply glue to the carpet and bodywork ?
- especially need advice or pictures on how to make the map pockets, as the carpet and pocket is just one big long section
- should I remove the old rear parcel shelf foam ?
- does anything cover this hole at the front centre ?
As always, thanks for your help, and hopefully this might help others in time.
I have posted base interior pictures on my photobucket.
Let me know if this all looks sound to you.
Ian
Ian Highfield
1992 964 C2 Manual with RS Suspension etc.
1973 911T Narrow body Hot Rod with 2.7 Carrera engine and loads of period modsl - SOLD
1986 Carrera Coupe Sport with Stainless Silencer and SW Chip (256 fwbhp) - SOLD
Old 02-11-2007, 04:19 PM
