			 Guest
					Posts: n/a
				Will a '70 901/911 trans handle a strong 3.0?
			Just curious - can a 901/911 trans deal with the torque of a 3.0 with carbs? Car (70T) would be mostly street with a little track thrown in for spice.
			 PRO Motorsports
			Yes, but that's extremely driver-dependant.
			Very little built-in margin left over with that drivetrain combo, but if you're nice to it............???? Just don't be a hero in first or second.
	'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3  |
			 Guest
					Posts: n/a
			Thanks Tyson - what would be involved in a 915 transplant into the 70?
	Tru6 Restoration & Design  |
 Sherwood  |
			 Guest
					Posts: n/a
			Thanks Sherwood(and Shaun),
	I have the 915 box and driveshafts. Will the shafts bolt directly to the 70 hubs?  |
			Depends on the year of the 915. I think a 74 is a bolt-on. later 7:31's may be as well. When you get to 8:31's, I think you'll need to change hubs or flanges or both?
			 RETIRED
			Ask the the 914 weenies.....
			OK....yeah....I had a 901 with a 3.0 and pounded the crappoutta it....the 1st gear burnouts are what killed it....took 3 years.... BTW....I have a early 915 in the garage....$900......
	1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel  |
			I've got a 901 paired with a 3.0 that's carb'd.  It's held up fine so far.....but as they say, as long as you're easy on it in 1st and 2nd....
			-Brian
	'67 912/6 hot rod - fresh build with lots of goodies - present '03 BMW E39 M5 - the daily '15 991.1 Carrera S - the new daily '68 911L 3.0SC carb'd hot rod - sold and dearly missed. '05 997S with all the right mods. Gone but not forgotten  |
			 Guest
					Posts: n/a
			Cool - so sounds like I can get by for a while with the 901. I even have an extra 901 in the garage for a spare. Thanks.
	Next question - Is the 901 to 3.0 a straight bolt up?  |
 I'll have to concur with Shaun. The early CV joints were 4-bolt, the later ones were 6-bolt. It's a matter of matching the CV joints with the gearbox drive flange on one end and the axle stub flange on the other end......or vice versa. The overall axle length may also be a factor. It's easier if 7:31 parts are used throughout (gearbox, axles/CVs and control arms) or all 8:31 parts. Sherwood  |
			I will agree with Tyson and say no.
			With a 3.0’s torque, the question is; How Long? With a great original set-up, new parts, proper oil cooling and regular maintenance rebuilds a type 901 or 911 will last acceptably long using a high revving 2.8S. A tourquie 3.0 is over the top IMHO. Sure it will work. The question is how long. Porsche engineers, in their usual early ‘70s conservatism, thought 2.2 liters the limit for the 901/911. They would have preferred to use the 915 with the ’70 2.2 but it wasn’t ready. On the other side, Porsche waited too long before introducing the G50 (950) transmission in the beginning of the “only profits count” era. It didn’t take much time for the G64 to show up for larger engine applications. What to do? With a 3.0 and larger, use a 915. If you have the opportunity, use the G50 or G64. (Remember, these last two require much modification.) Best, Grady
	ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50  |
			 RETIRED
			901 to a 3.0....no.  You will need an early flywheel or you can get one built by Kennedy Engineered Products in Palmdale CA....I've seen them build a new flywheel cheaper than a used one has sold for.  They also can do larger clutch faces and supply discs, pressure plates and TO for excellent prices.
			I've been doing business with them since 1975. Class act....
			 Guest
					Posts: n/a
			Mike - thanks, I have 2 - 901 flywheels at my disposal. Have to see what shape they're in tho.
			Mark, et all,
			This an entirely different issue from the choices among 901, 911, 915, G50 and G64 transmissions. Using a 215 mm push-type clutch with a 3.0 simply invites too regular clutch replacements and possibly a failure at an inopportune moment. It certainly isn’t appropriate for track use. A type 911 transmission is designed for use with a 225 mm pull-type clutch common from ’70 to ’89. I still think you are peeing on a live wire using a 901 with a hot 3.0. It may be a very painful experience, waste valuable parts needlessly, and be an expensive “learning experience.” Someone give me a counter argurement. Best, Grady
			 RETIRED
			KEP can put a 225 or a 228 clutch package together.....unless you are a dedicated racer...it's fine.  Keep the burnouts to minimum....even a 915 has it's limits.....
			 Bye, Bye.
	Elvis has left the building.  |
			 Guest
					Posts: n/a
			I'm buying a 3.0 with a nice rebuilt 915. I was just looking for the path of least resistance to get this little orphan car back on the road. If I use the 911, it will be temporary while the car is getting back road worthy.
			 Information Junky
	Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
