North Coast Cab's Avatar
Ingition Help - Guru Needed
I installed an MSD6AL, blaster coil and timing computer for use with an SC distributor. Currently there are no vacuum lines to the dizzy. I'm also wondering if I need to lock the advance in the distributor or whta I need to do at this point.
TIA, John
1985.5 944 GTS
Old 02-11-2007, 06:21 PM
eskimo's Avatar
Off topic. John, check your PM.
z's house of boxer, no longer a house of boxer!
03 buell XB9r, 03 Aprilia Scarabeo 50, 06 Jeep Commander 5.7, 88 911 Targa, S2 9.1 sailboat, Santa Cruz 27 sailboat, 18 BMW g310GS, 18 Beetle Turbo
Old 02-16-2007, 11:00 AM
John:
Not to worry. Simply cap off the cannister and use the MSD timing box to set the retard stages as needed.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-16-2007, 11:59 AM
Thanks Steve.
I finally tried to start the car today and after overcoming some other obstacles I didn't have any spark. Here is my ignition set-up.
MSD6AL Ignition System – Race Car
MDS6AL
BLK - Ground
RED - +
RED - +
WHT – YEL from Timing Control
ORG – coil +
BLK – coil –
MSD 8680 Adj Timing Control
BLK - Ground
RED - +
YEL – WHT from MSD6AL
WHT - OPEN
Mag Pick-up
Coil
- BLK from MSD6AL
+ ORG from MSD6AL
SC Distributor
Signal Cable
Center Conductor – GRN from Timing Control
SHLD – Voilet from Timing Controller
Any help would be greatly appreciated.
1985.5 944 GTS
Old 02-25-2007, 01:38 PM
I would connect the MSD 6AL directly to the trigger & coil and test for spark by cranking.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 02-25-2007, 02:24 PM
