Switching To Synthetic
I've decided to take a chance by switching to Mobil 1 supersyn 15w-50. Anyone using this grade? How is it working for you? I'll be crossing my fingers and hope that no leaks occur. We're taking off Saturday for a weekend jaune up north on Hwy 1 to Fort Bragg, CA.
It's going to be in the 100's in the sacramento valley over the weekend so the coast will be in the 70's. I was in the MobilOil site and it recommended full syn Mobil 1 trk & suv 5w-40 for my car.
Carl, |
Carl,
I've got M1 15W50 in my '77. It had a rebuild 35,000 mi ago and has the upgraded chain housing covers (that go with the hydraulic chain tensioners) and Carrera valve covers. It doesn't leak. I've only had the car 3 months but have the records that indicate its had mostly synthetic oil but with the occaisonal non-synth change as well. I'd go go for it.
'77 911S sold in 2006 '79 911SC in 2009 ![]() Saskatoon Sports Car Club http://www.ssccracing.org/ |
Am I the only one using blends? I use Valvoline Dura-Blend 20/50, and I think it is great! Even after DE's and Texas heat, the oil from my 122K motor looks great when I change it. I don't run the risk of the seal problem, and I get the benefit of synthetic IMO.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
If you're concerned about leaks, why would you want anything but the most viscous M1 oil.
I switched to Mobil 1 in my old car and the leaks went from adding a quart every 1000 miles to 300 miles. Consider a synthetic blend (the castol one isnt bad). I know widebody911 uses it and it works quite well, even on the track, with just minor leaks.
991.1 RS - Lava Orange 991.1 GT3 - Sapphire Blue - gone 997.2 GT3 - Guards Red - gone 996 GT3 4 Liter - Basalt Black - gone |
Just had major tune up approx 2-3 weeks ago. New valve cover gaskets, already had the upgraded chain tensioners and I believe I have the Carrera valve covers. My compression test was excellent at 165, 164, 165, 164, 165, 164. The last grade I used was Castrol GTX High mileage 20/50. Just curious though, I know that not all the oil drains out and that about 2 qts remain in the system. Is it harmful for the Mobil1 supersyn to mix with old oil? I really don't feel like disconnecting any of the oil lines to drain the rest. I was thinking of using my old shop vac to suck out the rest through the oil tank.
Carl, |
Stranger on the Internet
Carl:
There is lots of information (and mis-information) regarding oils. Here's some light reading for you. There are some very knowledeable oil guys here though. The beauty of this board is that there are lots of guys with diffrent areas of expetise, in which they know stuff cold. Oil is pretty important, so read up. I am likely one of the minority who has dino, and refuses to switch...had a leak problem once before. I only have to drop a bowling ball on my foot once to know it hurts. Pat when mobil one 15-50 is gone, what will you use? Why are new engines OK on synthetic but old ones leak?
Patrick E. Keefe 78 SC |
Designer King
Not an oil expert, but to answer your question, I've been using Mobil1 15W50 for the past year and a half without any leaking.
BTW rebuilt, enlarged engine has approx 75000mi on it.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
On both you 911s, how old are your seals and gaskets. Mileage on your 911s?
Carl, |
Ova Day
Using M1 15w50 in my '88 3.2 Carerra. Doesn't leak a drop. I think it has had synthetic only since day one. Oil return lines have been redone once. Only 40k on the clock so far. The PO only put on 16k in 12 years! It seems to use about 1qt/1500 miles.
I don't know if I would switch TO synthetic after many miles of dino in a car but I'm comfortable with staying with it when there are no apparent problems.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 |
Go with the 15/50 viscosity. Amsoil makes a 20/50 high performance synthetic oil for those who want to keep the same viscosity grade and try something different. Don www.lubedelaer.com/dstevens
72T Coupe - SOLD :-( |
10/40 synthetics and it is working good
durn for'ner
Last year Mobil 1 0w40. Untouched engine at 90k miles. No leaks.
This year Castrol 5w40. No leaks.
Markus Resident Fluffer Carrera '85 |
I just switched from Kendall GT1 to Mobil 1 15-50 Extended Life. 88 Carrera, stock motor, 114,000 miles.
The slight weeping I have at my cam towers has not worsened. Oil consumption has not changed.
Mat P 1988 911 Carrera |
19 years and 17k posts...
Just used AMSOIL 20W50
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
So many "synthetics" today contain a mix of type III (HC dino) and IV base stocks that you're really getting a blend. Some suggest even Mobil 1 is. The leak question is a non-issue and shouldn't be a basis for choosing an oil unless your engine is using NOS seals that were manufactured over 25 years ago.
I just did an oil change this past weekend on my 88 911.
I've been doing way too much reading here and on other sites. I like synthetics and used to use Redline 20/50. It got hard to get here where I live. All my reading lead me to Mobil One V-Twin oil. V-Twin is VERY expensive !!! about $8.00 a quart at Wal-Mart. Wal-Mart also sells Mobil One 15/50 full synthetic by the 5 gallon jug for about $24.00. I'm a risk taking kinda guy, I also am not wealthy so $100.00 oil changes are out of the question. I was spending about $70.00 for the Redline so... I thought try 5 quarts of V-Twin and 5quarts of the 15/50 kinda make my own blend thing. I feel good about the combo from what I read, this should do the trick. The way I see it... oil is kinda like vitamins. You get what you think you need to protect you ! Chuck |
Me like track days
An old engine such as a non-rebuilt 1983SC that has seen dino oil all it's life may well result in some significant leakage with a pure synthetic.
Be ready for it.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
MAGA
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Me like track days
Agreed, Tim. The hell it isn't an issue.
It is a "known" and happens more often than not.
AKA SportsCarFan
I switched to Mobil 1 last summer at 50,000 miles. I was concerned about leaks (it had never leaked a drop before). So far, it still has not leaked at all.
Doug Miller 1988 Guards Red Carrera |
