87-89 Trailing arms different?
All,
I have a question concerning the trailing arm update for early cars. are the G50 Carrera trailing arms different than 915 SC/Carrera trailing arms found on the 78-86 models? I found one article here http://forums.pelicanparts.com/showthread.php?s=&threadid=321709&highlight=carrer a+trailing+arms but I didnt find an answer unless i overlooked it. Thanks, |
1978 - 1989 911 trailing arms are the same. Part # is 911 331 513 06 The Turbo trailing arms are different.
There I go. Learning again from you guys.
Had a debate the other day with a friend. I claimed just that - that the trailing arms on the G50 was the same as the turbo. I should keep my ignorant mouth shut.. |
syncroid,
thanks for the quick response. for some reason, I thought the pickup points were a little bit different because of the shorter torsion tube to allow for the G50. But if they are the same part number, then its the same part! I should have thought to lookup the part numbers :) |
Glad to be of service.
| All times are GMT -8. The time now is 09:44 AM. |
