Black and Blue
87-89 Trailing arms different?
All,
I have a question concerning the trailing arm update for early cars. are the G50 Carrera trailing arms different than 915 SC/Carrera trailing arms found on the 78-86 models? I found one article here trailing arm question but I didnt find an answer unless i overlooked it. Thanks,
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
1978 - 1989 911 trailing arms are the same. Part # is 911 331 513 06 The Turbo trailing arms are different.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
durn for'ner
There I go. Learning again from you guys.
Had a debate the other day with a friend. I claimed just that - that the trailing arms on the G50 was the same as the turbo. I should keep my ignorant mouth shut..
Markus Resident Fluffer Carrera '85 |
Black and Blue
syncroid,
thanks for the quick response. for some reason, I thought the pickup points were a little bit different because of the shorter torsion tube to allow for the G50. But if they are the same part number, then its the same part! I should have thought to lookup the part numbers
Glad to be of service.
