haycait911's Avatar
cheap/easy/ not correct wndshld trim strip replacement
PURISTS AVERT YOUR EYES!! I took out the windshield insert trim on my '73 to paint it last year, only to discover it DOES NOT go back in with shield in place. after stewing on replacing the seals and possible glass breakage in the process I finally came up with a temporary(?) solution to my problem. I found some rubber tubing of a correct diameter (turns out to be 6mm after some experimenting) and with a lot of WD40 and a plastic windshield tool inserted it into the shield trim rubber channel. spreads the trim out to about where it's supposed to be. NOT correct but a workable solution for now. FWIW. Don.
Old 02-13-2007, 10:06 PM
If the tubing takes a "set" over time ( becomes smaller diameter)...there might be trouble in store.
How 'bout black insulation, solid core wire for this ????
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-14-2007, 10:26 AM
rw7810's Avatar
Where did you get the tubing?? I used a #8 or so electrical wire from Home Depot and it worked OK, but has a shiny exterior plastic coat that I wish it didn't. I like your find.
Robert Williams
70' 911T
Old 02-14-2007, 10:38 AM
IROC's Avatar
6mm. Committing that diameter to memory...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-14-2007, 10:40 AM
jmshepard's Avatar
well done Don!
I say we take off, and nuke the site from orbit. It's the only way to be sure.
2009 Cayman
Old 02-14-2007, 11:15 AM
haycait911's Avatar
the tubing may collapse over time but I do intend to replace the seals, maybe next winter. the tube I found only has a 1/16 ID so shouldn't change much. I found the tube at the local parts shop, think it might be vacuum tubing because of the very heavy wall. one of those 'temporary' fixes that tend to become rather long-term. thanks for the comments, Don.
Old 02-14-2007, 11:26 PM
audi2.7t's Avatar
FYI... you can actually buy solid rubber lock beading in different diameters from auto glass suppliers....look for one that supplies/installs heavy truck windshields. Also, for a few bucks you can buy the tool to install it.
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 02-15-2007, 07:17 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey HayCait911,
Do you have a pic of your final work???
'85 Carrera Targa
PCA/POC
Old 04-27-2008, 11:10 PM
haycait911's Avatar
sorry, sold that car. but worked fine and seemed to hold it's shape.
Old 04-27-2008, 11:12 PM
DRACO A5OG's Avatar
Oh Congrats!
Thanks for a Great Thread!
'85 Carrera Targa
PCA/POC
Old 04-27-2008, 11:18 PM
