1972_911T's Avatar
MFI Butterflies
Does anyone know what angle the chamfer on the edge of MFI butterflies should be machined at? is it 8 degrees?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 02-17-2007, 01:42 AM
1972_911T's Avatar
Just cleaned up the disks in my throttle bodies and there stamped as 6 so I presume they are machined at 6 degrees. I have some replacements that are stamped as 78 degrees so I presume this is equivlent to 12 degrees just measured the other way.
Do you think the throttles closing 6 degrees earlier will cause issues with the pump linkage as there will be less movement on the pump arm between closed and full open throttle? MFI Gurus?
1972 911t RS Styled
Old 02-17-2007, 11:23 AM
