Somatic Negative Optimist
Gunter's Avatar
Question Best adhesive for metal on metal?
I intend to glue some small brass letters onto Aluminium backing.
What glue would work best?
Thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-18-2007, 10:45 AM
Paul K's Avatar
I have no idea if this would work, but have you considered JB Weld?
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 02-18-2007, 10:56 AM
haycait911's Avatar
go see your friendly body shop with bits in hand and get them to use a two component ' panel bond '. it's specifically for metal to metal. clean both sides right before glueing, aluminum oxidizes in 1/2 hour and you won't get as good a bond. for less permanent use 3M emblem adhesive. clear sheet of sticky stuff. apply to letters, peel off backing and apply. used by bodyshops for emblems. JB weld would work great too, but be sure to clean metal first. Don.
Old 02-18-2007, 11:04 AM
scottb's Avatar
+1 for JB Weld. That stuff is incredible, and will be more than adequate for what you're doing. Be sure to "scuff" both surfaces being glued with a Scotchbrite pad or some sandpaper.
Once bonded with JB Weld, you'll never get the pieces apart!
1984 Targa
Old 02-18-2007, 11:13 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Epibond 420 is my preferred one...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 02-18-2007, 01:03 PM
Administrator
Jack Olsen's Avatar
I did my wing with 3M Scotch-weld DP460. It's a structural adhesive used for things like bonding flares to a chassis. Probably overkill for an emblem. Trim adhesive tape is out of the question?
Old 02-18-2007, 01:47 PM
IROC's Avatar
If you never want it to come off again, use 3M EC 2216.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-18-2007, 02:13 PM
Al S's Avatar
Gunter, for bare metal surfaces, I've had good results with "Lexel", available at your local Rona!
It's slow to cure (days), but once cured, very strong (it stays rubbery).
Al
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 02-18-2007, 03:29 PM
defcon65's Avatar
+2 on JB Weld, it will glue air to water and anything else you have laying around that needs to be stuck together...
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 02-20-2007, 12:41 PM
"I have found JB Weld to be better than bailing wire."
pat
18,000mi a year 84targa
Old 02-20-2007, 01:25 PM
sithot's Avatar
The structural stuff is pretty incredible. I just recently saw the Natl. Geo. tour of the Peterbilt factory. They use robotics and it was pretty interesting to see the arms apply the adhesive to the cabs. That's how they do it!
A friend uses it in his body shop and swears by it. Like Jack said it's great for flares and such.
Best,
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 02-20-2007, 03:20 PM
scottb's Avatar
Keep in mind that he's just asking about some small brass letters being glued to aluminum. My guess is that he doesn't need structural adhesive to do the job! A trip to the local hardware store for JB Weld or something similar will be more than adequate.
1984 Targa
Old 02-20-2007, 04:44 PM
