-   -   variation of the engine timing and 5000 rpm max, carrera 1985 (http://forums.pelicanparts.com/porsche-911-technical-forum/331036-variation-engine-timing-5000-rpm-max-carrera-1985-a.html)
ashmed 02-18-2007 09:56 AM
Please help me, i have a 911 carrera 1985, the engine was run perfectly, i change de clutch, and when we put back de engine is fail, because i cant get the same stability of the engine and i cant go further than 5000 rpm, someone knows why?
<br>
http://forums.pelicanparts.com/uploa...1171820900.jpg
DanielDudley 02-18-2007 10:50 AM
Check all your hoses, and clamps for a vaccume leak. Make sure the throttle is going to wide open. And relax, it is something minor. You will find it.
