2.7 guru which Piston?
my engine is going to be open for a rebuild.
From my research on this board and wayne engine book. 2.7 engine mod and upgrade 1. RS P&C, s-cam, carb or MFI same comp ratio 2. from this http://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild2.htm retain CIS, 964 cam, hi com piston up to 9.5:1, or even 9.8:1 i went thru my part bin and i got webber (size 40) and a pair of 964 cam. 1. should i use webber with 964 cam? 2. RS piston with same comp or Hi com piston above with webber. this will go into 1966 swb with 915. i am looking for more fun (car is street use mostly and some trackday)and since i already have 964 cam and webber, streching to a set of new P&C is still in my budget. we have only 91 octane fuel here, if that make a differnce. emission control is not an issure here. cheers and thanks tenn |
