sc and 3.2 carrera clutch differences?
Hi guys,
I've got a new clutch, and was looking for an exploded diagram to make sure i get everything right. I went into the tech info centre and found the diagrams for an SC. Is it the same as for a 915 3.2 carrera? If not, can somebody please post an exploded diagram for a 915 3.2 carrera. Cheers, Adam |
The parts catalog here shows the same clutch part number for 1974 to 1986. That seems to include 2.7, 3.0 and 3.2.
The same size 225mm clutch was used for all 915 transmission cars, '72 -'86
There are different versions, I prefer the earlier spring centered sport clutch, over the later rubber center version |
Spring centered appeared as factory-installed around Spring '83....going through the end of 915 production through the '86 MY.
- Wil |
ok thanks a lot for your replies.
Seems that the SC clutch diagram will be ok |
| All times are GMT -8. The time now is 01:44 PM. |
