sc and 3.2 carrera clutch differences?
Hi guys,
I've got a new clutch, and was looking for an exploded diagram to make sure i get everything right. I went into the tech info centre and found the diagrams for an SC. Is it the same as for a 915 3.2 carrera? If not, can somebody please post an exploded diagram for a 915 3.2 carrera. Cheers, Adam
_____________________ '73 RSR Interpretation ---------------------------------- |
The parts catalog here shows the same clutch part number for 1974 to 1986. That seems to include 2.7, 3.0 and 3.2.
Tony G 2000 Boxster S |
The same size 225mm clutch was used for all 915 transmission cars, '72 -'86
There are different versions, I prefer the earlier spring centered sport clutch, over the later rubber center version
Spring centered appeared as factory-installed around Spring '83....going through the end of 915 production through the '86 MY.
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-20-2007 at 03:46 PM.. |
ok thanks a lot for your replies.
Seems that the SC clutch diagram will be ok
