Put SC flares back on, new problem
In order for my car to be PCA Race G - Stock legal I had to put back my rear flare to stock so I bought some flares from a gentleman here.
When installing them, as my quarters had been "baseball bat flared", I went by the torsion tube holes for alignment. Once the front was right I simply squared up the rear and that's where they went (cut and but welded in). All was well until I put the wheel on and loaded the suspension (just with the weight of the car+me). There is about 2.5" of clearance in the front of the wheel but only about 1" in the rear. I rechecked the torsion tube and the hole in the quarter is perfectly aligned. I also noticed, once the wheel was in place, that the shape of the flare seems more squared off than I remember mine being originally, and not even square to the ground. None of this is readily apparent on the lift... and both sides are exactly the same. The only other thing that may play a part is the new rear RUF bumper. It's "possible" IT is the wrong width and pulling in the quarter panels in that area. Any ideas?
Gary R. Last edited by GaryR; 02-20-2007 at 06:39 AM.. |
Insert Tag Line HERE.....
gotta see the pic on this one..
Marc |
Got her outside and took her for a ride. With the lip pulled out to the outside (rear) edge of the tire I believe I won't see rubbing, at least didn't get any on the very bumpy road here..
The gap between the front edge of the quarter and the tire is 2.5", 6.5" from center of torsion tube to tire, top of flare is 12" from body to outside lip, torsion tube height id 10.25" and fender lip height is 25" at wheel center...
Gary R. Last edited by GaryR; 02-20-2007 at 04:54 AM.. |
That's messed up.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
It's a race car, couldn't care less about looks if it functions but I believe you may be right Noah. I'll have to position the flare irregardless of the torsion center position with the wheel in compression (car's weight).
Thanks for the great insight and help Paul..
Gary R. Last edited by GaryR; 02-20-2007 at 06:45 AM.. |
Though you didn't give a straight on side shot, It appears the front of the flare is correctly mounted at the front but the rear seems to be pulled too far forward. I guess you could check by measuring the wheel well opening of an SC to see if its correct.
Were these steels flares? Weird. Last edited by Dueller; 02-20-2007 at 07:23 AM.. |
With the car on the lift and wheel in place it looked perfect due to the wheel travel downward. As everything was aligned I *assumed* all was well. Next time I will obviously place the panel with wheel position as the basis and damn the torsion tube..
Gary R. Last edited by GaryR; 02-20-2007 at 07:20 AM.. |
Well, I see what you did wrong, but it will be hard to explain. Basically, if you raised the rear part rotating upward using the torsion bar hole as the pivot point, the lip would rise over the rear part of the tire. That would put the lip more level to the ground plane and give the more equal clearance to the tire. You seem to have added too much of the donor fender under the rear points of the quarter window and on back. I know the contours may have suggested that was right, but obviously, it wasn't. Now, how that would have lined up with where the bumper goes, I don't know. I can't tell anymore from just one pic.
This is the first pic I could find. Notice the shape of the wheel arch. It's somewhat squared as you describe, but level.
Thanks Milt, I fully understand what you are saying, I just don't get how I could have rotated the donor flare up, keeping the torsion hole aligned. and had the rear (bent under part) not be way out of alignment with the original rear.. or are you saying I shouldn't have worried about it and just did what I had to (which in hindsight makes the most sense). Again, I made the mistake of assumption... THAT won't happen again!
Again, due to the way the wheel travels I *may* get away with this for track use if I keep the lip pulled out to the tire's outside plane and widen the rear bumper to hold it out there.. If it was a road car I would redo it and not look back but after a race or two I may have to anyway if you know what I mean...
Gary R. Last edited by GaryR; 02-20-2007 at 07:56 AM.. |
+1 for Milt.
Looking at the picture after reading his response it does look "obvious" that the wheel well is rotated down in the back with the torsion hole as the piviot point. If you look at the relatively flat part of the arch (should be at the top of the wheel well), it should be parallel to the ground but is tilted down to where it almost touches the tire. Looks like a redo.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
As I said, it's hard to explain. I don't see how it all would have come together either, yet that seems to be the problem.
Next one I know just what to do!!
Gary R. |
GAFB
You started tacking from the front, I'm willing to bet? As you went around, the flare started 'cupping' on its radius, and all the runout (is 'run-in' a word?) accumulated on the rearward half of the stamping. OR, it may have happened when it was cut from the donor and you didn't notice it during the install, but that's what it is. You can see it in your pic -- split the flare in half along a vertical axis. The half to the left starts a pronounced trip down that should be more horizontal.
This happened to me when I tried to roll the lips on a set of Turbo flares prior to installing them. When I rolled the lips, the entire flare cupped in and tightened the radius of the wheel well. Then when I went to install, they'd line up more or less but just didn't look right. We won't discuss the primitive methods I used to unload the stress from the metal...
Several BMWs |
Live and learn.. I do all the work myself so a do-over is only more time....
Gary R. |
GAFB
Several BMWs |
Gary, looks like you have the ultra-rare RLWB (really long wheelbase) version of the SC!
But seriously, this post is intended to provide encouragement to cut it off! Lime Rock is at the end of April, you will be fine! Good luck!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
John, I shortened the trailing arm instead.. all set now!
Gary R. |
Gary R. |
