FinallyGotOne's Avatar
Question 1979 911 what is this, do I need it see pic
What is this? my 79 911 SC. Had the decklid off and the brackets so that I can make the passenger side bracket. These straps just seem to rap around the stock brackets on both sides but thats it. are they some sort of safety strap to keep the decklid from flying off? seriously what are they and do I need them?"
Old 02-19-2007, 06:12 PM
Less brakes, more gas!
euro911sc's Avatar
Grounding strap for the deck lid, I believe. Should be bolted to deck lid through bracket bolt and then also to the sheet metal in the car or the rear bracket mount.
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-19-2007, 06:15 PM
yeah, looks like a grounding strap to me, bt why the hell would you need to ground your decklid?
66 911... no more
90 mazda miata
76 unimog 406
Dune Buggy!
Old 02-19-2007, 06:17 PM
you dont need it. your hinges [provided no composite washers] ground it out for you.
66 911... no more
90 mazda miata
76 unimog 406
Dune Buggy!
Old 02-19-2007, 06:18 PM
thanks guys! Guess I'll go ahead and put them back on. I'd love to hear the technical requirements of this from the tech heads on this site....
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 02-19-2007, 06:23 PM
Early_S_Man's Avatar
Porsche Crest
The VDE is/was the German equivalent to our FCC, but more stringent regarding vehicle emissions of EMI [electro-magnetic interference] and RFI [radio frequency interference ... consequently, when CDI was fitted to the 911s the guys in Stuttgart went overboard to insure that the fast-rise 46kV lightning bolts running around didn't escape to some distant govt. minister's Mercedes' radio. Could have been worse ... they could have fitted shielded aircraft spark plugs and connectors!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-19-2007, 07:52 PM
ok. so I really dont see any need for it now!
1979 911 SC
Old 02-20-2007, 08:36 AM
Porsche Crest
As long as your radio/stereo work without any annoying static directly related to engine rpms without the 8 ga equivalent ground strap in place ... I think you could do without it, but don't toss it in the dumpster, yet. If ignition noise in the radio shows up ... you already know what the fix is ...
Warren Hall, Jr.
Old 02-20-2007, 10:58 AM
o. shoot okay, then i will definitely be putting them back on!
1979 911 SC
Old 02-20-2007, 11:03 AM
I just did some deck lid work and had these off on my car. They are grounding straps but I can't tell you what they're for. My straps (88 coupe) were attached as seen in the photo and ran under the deck lid hinge as the photo shows. They bolted to the hinge bolt itself. Holes in my strap were different size and the smaller hole goes on the lid hinge bracket bolt while the larger hole goes on the hinge bolt.
88 911 Coupe
09 Jetta Diesel
10 Honda Accord
88 450SL
95 Sabre 362
Old 02-20-2007, 01:59 PM
David's Avatar
Be sure and weigh it so you keep a running list of all the things you take off the car
Old 02-20-2007, 02:26 PM
thats funny!
1979 911 SC
Old 02-21-2007, 08:51 AM
