name this relay
hey guys.
this is on an 80sc. i have wiring diagrams for everything except the 80sc. you can see the black plastic housing is broken exposing the insides. plug is bolted right above washer pump relay has 5 spades.P,56,31,30,S what is the relay for? wire,s on plug are . red/white, yellow/black, 2grey,and brown thanks in advance Brucehttp://forums.pelicanparts.com/uploa...1172014336.jpg |
Bruce, I think thats the headlight washer relay. The grey wires are daisy chained on terminals 56 and S. From S, a grey wire goes back to the headlight washer switch. The brown wire is ground. The yellow/black from terminal P goes to the headlight washer pump. The red/white on terminal 30 goes back to the fuse panel, fuse 19 [25 amp].
thanks ron . by naming it I know where to look in a wiring diagram
thanks again |
| All times are GMT -8. The time now is 09:58 AM. |
