lonewolf's Avatar
name this relay
hey guys.
this is on an 80sc.
i have wiring diagrams for everything except the 80sc.
you can see the black plastic housing is broken exposing the insides. plug is bolted right above washer pump
relay has 5 spades.P,56,31,30,S
what is the relay for?
wire,s on plug are . red/white, yellow/black, 2grey,and brown
thanks in advance
Bruce
Old 02-20-2007, 03:32 PM
Bruce, I think thats the headlight washer relay. The grey wires are daisy chained on terminals 56 and S. From S, a grey wire goes back to the headlight washer switch. The brown wire is ground. The yellow/black from terminal P goes to the headlight washer pump. The red/white on terminal 30 goes back to the fuse panel, fuse 19 [25 amp].
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 02-20-2007, 05:21 PM
lonewolf's Avatar
thanks ron . by naming it I know where to look in a wiring diagram
thanks again
Old 02-20-2007, 05:42 PM
