Czar of C.R.A.P.
dfink's Avatar
test port pinouts
Just curious about the pinouts on the test port for the 3.2 engines. I know that two of them are jumped when setting idle but what are the others for. Could find anything doing a search.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 02-20-2007, 02:17 PM
Czar of C.R.A.P.
dfink's Avatar
Nobody.....
66 912 Coupe
Old 02-21-2007, 06:21 AM
Czar of C.R.A.P.
dfink's Avatar
Someone must know something.....
66 912 Coupe
Old 02-22-2007, 08:32 AM
sudo apt-get purge 930
equality72521's Avatar
You may find reluctance to give advice on this subject. Even if I knew the answer I would be hesitant to tell you for fear of helping you burn up something expensive.
--clutch-monkey
Old 02-22-2007, 08:48 AM
Czar of C.R.A.P.
dfink's Avatar
Ah somebody is always telling someone to stick something someplace. I have had nearly every part of this car apart and poked stuff already where I probably shouldn't have. I am going to assume that the test port has some function other than centering the ICV for mixture setting which I have done and don't think anything burned up yet.
66 912 Coupe
Old 02-22-2007, 09:28 AM
