please explain coil overs
I know the answer is in the threads somewhere....
Corect me if im wrong ( Im a computer guy, not mechanically inclined ). A coil over is a shock\spring combined? Can it be used to adjust ride height instead of tinkering with torsion bars? I have a car that I want to replace the suspension, or tweak the torsion bars, etc, why do more people not upgrade the suspension to coil overs? Does this allow one to get rid of torsion bars altogether? I know some re-enforce things for coil overs. Can someone explain the basic changes to the car, the benefits, and maybe why more people dont go this route? Or point me to a thread where its all explained. Thanks |
Coil overs are indeed a shock/strut w/ a concentric coil spring. Some, but not all, incorporate height adjustment collers
This set has a wide range of adjustment http://forums.pelicanparts.com/uploa...1172170158.jpg This set has a small range of adjustment on the front but none on the rear http://forums.pelicanparts.com/uploa...1172170211.jpg All 911s from '89 up(964.993,996,997) have coil oversuspension stock Older 911s can be fitted w/ them but there are somerissks and drawbacks to using them where they weren't designed in. As you indicated one of the best potential features of coilovers is height adjust-ability, a second is a wider range of spring rates. |
Do they allow you to remove torsion bars?
Is there a good thread on the steps to re-enforce the car to allow for the install\use of coil overs? Doesnt look like Pelican sells them either. What are the risks\drawbacks? Is it cost prohibitive to switch to coil overs if your replacing the suspension anyways? I get the impression people would like to upgrade but they dont, why? Cost? |
Yes it will mean that you do away with torsion bars but it also means that you are supporting the weight if the car by the shock mounts. This means you will need to reinforce the car. It isn't a trivial project.
A third is the ability to use differential spring rates based on the amount of displacement of the suspension - see the thinner, differently wound "ends" of the purple springs that Bill posted.
Today, Porsche uses a lot of such tricks - the newr cars depend on the rubber stops for some susp. compliance according a 2-part susp. test in Pano - it was done by an MD and an engineer IIRC -- about 2 years ago. Worth reading. |
I'll let the expert chime in but this is what I understand...
Besides ride height & spring rate that Bill talked about, some system also have adjustable rebound/damping rate. All these are features not easily (or possible) done with torsion bar. I think most shy away because of price. Wrt chassis reinforcement - I'm on the page that the suspension point was not designed to take "vertical" load. So, can you remove the torsion bars? Yes. Will it cause long term issue, IMHO, yes. I have heard there are many out there who did this without reinforcements and have no problems. But I'm not comfortable with the idea. |
Koni, Leda and Fox all have adjustable 911 dampers for t-bar suspension. Not all coil overs include adjustable damping either, the higher end products from Bilstein(PSS9), JIC, Moton etc. do. But there are many that do not like Bilstein HD. Yes, the multi adjustable systems are very expensive and not for everyone. Coil overs for 911 started as helper springs to get higher rates than could be obtained form t-bars alone. |
Easiest definition: coil (spring) over (shock). If you look around in the archives a bit, you will see conversions. Some of the reinforcement recommended is not all that difficult for a fabricator of modest talent. Many times, though, this conversion accompanies installation of a multi point roll cage and the suspension points in question here are picked up into the cage structure. This gives the car a lot less body flex as well as the needed reinforcement. After all, a real trick set up on just a street car may be lost in terms of the added performance. A significant amount of work for only the ease of adjustment.
Some threads posted in the past were authored by "Tyson Schmidt." Refer to "BBII" in your search. (BTW, I don't mean to infer that Tyson is of "modest talent." Quite the contrary.) |
There is pretty much zero benefit to making the change unless you are racing the car. Coils allow stiffer spring rates than the thickest torsion bars. Going that stiff doesn't make much sense for street use. Plus, coils reduce wheel and tire clearance in the front, and require dropping the engine and welding in reinforcements around the rear crossmember.
For track use, the advantages are: easy and quick height adjustment, the ability to quickly change springs out, and (as mentioned above) the ability to run stiffer spring rates than available torsion cars allow. People who do it for the bling factor confuse me. I got rid of my coils in the front in order to fit wider wheels and tires. |
"People who do it for the bling factor confuse me."
- And you live WHERE??? It's the Bling Center of the Universe. How can you be confused? |
Regarding the pro's and con's
here are a few: con - generally not legal for stock type racing - moves weight higher up in the chassis and increases the amount of unsprung weight - alot of expense for zero gain if you continue to use streetable spring rates - I would argue that the front ride height is as difficult or perhaps more difficult to adjust with a coil over. pro's - bling - alows quicker spring rate changes. In fact this is one of two only REAL arguements for using a coil over. If you go to a track event and swap your spring rates 2 or 3 times a weekend, then yes you want a coil over - REAL arguement #2, coil over spring rates come in a greater range and selection. converting a street car to coil overs puts you into the bling catagory and causes racers to laugh behind your back brant |
but don't you need the coil-overs so that your ginormous wing won't look out of place on you '93 civic? |
Well, I'm not laughing at anyone who undertakes such a project. Maybe the thread starter is unaware of the fact beginning with the 964 model, the 911 had coil springs. Still does. And, the 914 had them in the rear from 1970. The earlier 911 just wasn't designed for them, not that they aren't an improvement, properly installed.
Now, I have to ask about the dynamics of the coils aside from being able to have much heavier ratings. It seems to me that the torsion bar is limited to a certain set of characteristics, whereas the coils have become rather sophisticated in design using progressive winding, etc. From my vantage point, today's coil springs are not your father's springs. Can some engineers help on this perspective? |
my 2¢ Now... on to the engineering! |
Look up, young Jedi....
I put them on the rear of my car for no good reason. My intention was to get a spring that was the equivalent of my old 28mm t-bars, so I think the springs are 225lb. Call it bling, or whatever, I could care less, I just wanted them. They are lighter than a strut/t-bar setup and easier to adjust. Its an easy enough mod for the next owner to undo if they don't like it.
You can get more progressive spring rates (ie non-linear) from coil springs. This would be of more benefit on the street, though. Small bumps and dips in the road would be absorbed by the tighter windings, while full support would only be provided under extreme cornering or braking. I would think for track use you would want fairly stiff spring rates at the sacrifice of a comfy ride over washboard surfaces.
Changing ride height with torsion bars isn't overly difficult. Getting your corner balance back is. But changing the springs to stiffen the ride is a fair bit easier than changing torsion bars (again with the corner balance issue). |
Me in my younger, stupider days...decided it would be a great idea to install coilovers on my 77 911 turbo, but not just any setup, I yanked everything out and did ERP 935 spring plates in the rear, monoballs on all the joints from and back, Smart Racing 31 mm sway bars from and rear, with Bilstein RSR threaded shocks and struts with RSR valving and 425/550 springs.....and didnt reinforce anything....oh, and all on a daily driven 2400 lbs 400 hp 930....and did I mention that I live in the tri state area...about 20 minutes from manhattan...so the roads are tip-top around here. Needless to say, the first time I pulled into a steep driveway, I literally tore the rear sway bar mount clen off the chassis, and then this other time at 1 am in the middle of the ghetto in Newark, I went over an expnasion joint in the road that busted the entire rear upper shock mount inside the engine compartment off the chassis and sent the top of the rear shock piston poking through the rear firewall and suck the ass of the car down so the tire was resting on the underside fo the rear flare. So reinforce I guess is what Im trying to say....or drive on a pool table
I still am running this same setup on my 77 930 and couldn't be happier! On the track it feels stuck to the race surface...on the street I do suffer from the-not so-maintained roads in LA, but who cares? I don't! Rear torsion bars were always a royal pain in the a$$ to adjust ride height. Bling? ok,.... laugh behind my back.....I wouldn't hear you anyway over my fire-belching exhaust! :D Cheers! |
So are you guys adjusting your ride heights once a week?
perhaps changing your spring rates every weekend? that extra reinforcement weight makes it hard to hit 1837# brant |
What a car! |
"I would think for track use you would want fairly stiff spring rates at the sacrifice of a comfy ride over washboard surfaces."
- Yes. Also, the change in rate is a non-linearity and can throw off the driver when racing... |
Touche!
Note to self: never drive in Newark, NJ. ;) |
Cheers |
4 gallons of gas?! I can only go ~20 miles on 4 gallons, I'm jealous! :) Post some pics of your car? |
I have the Bilstein RSR front struts in my 3.2.
I think I can add some additional comments that were not yet covered. Pro (Bilstein RSR or SRP/ Fox setup): - front spindle is VERY stiff, due to extra reinforcement. You can feel the steering is made more precise as a result. - rebuildable, and revalving is possible on all Bilsteins. Pro (Coil springs) - lighter than torsion bars - more selection in spring rates - torsion bars put a lot of stress on the upper surface at the rear of the front A-arm. You either have to swich to plastic bushings eventually or face a very costly replacement for the factory A arm about every 5-10 years or so. Coils will let you keep your old A arms, since the stress is carried on the upper mount, as described. Con - torsion bars are self-damping. This means that after you hit a bump, they do not continue to oscillate up and down. Coils will definately wallow up and down after hitting a bump. - the needle bearing seats that you need to install at the bottom of the coils between the spring perch and the coils need constant cleaning and lubrication. Corrections: - The original post asked if coils allow easier height adjustment. The answer is that both coils and torsions allow easy height adjustment, with the exception being the rear of the torsion setup, where height adjustment is a pain in the fanny. - I'm not entirely sure that the original RSRs had reinforced mounting points for the upper strut area. Later RSRs definitely had this area reinforced and tied to the roll cage, as Jack mentions. - Ride height is a separate issue. You can tear the ***** out of any 911 by hitting a big road hazzard or pothole, if it is lowered too far. I'd recommend contacting Smart Racing Products for advice on installing their coil over setup. Theirs looks to be very well made, and thought out very well. I also forgot to mention that you can put any raised spindle setup in the car (Bilstein RSR, or SRP/Fox) and keep your original torsion bars, just don't install the coil springs. |
mmastro, I hope you know Im only teasing with you .;) Newark is a great drive, like a human autocross:D
And those were the days.....the 8 mpg days. Took a while to figure out why the old 930s got such crummy gas mileage, for a 20 gallon fuel tank, 10 gallons went to the motor, and the ohter ten got blown out of the exhaust and lit inot a 5 foot set of flames, so in actuality those old turbos really got 16 mpg, since most of the fuel was used to scare the **** out of the traffic behind you, not actually propel the car forward |
I'm sure I'll get tired of the ride....when I'm 65.... ;) You were always willing to share your wealth of 930 knowledge, and I appreciated it. Cheers, |
plus I lost the motor on my street 914 on monday and worry that I will miss out on a lot of summer fun from it. sometimes there is benefit to "keeping it simple" the gains from a coil over conversion are real. but they are only justified on full out race cars and even then they are not that rewarding in cost$=performance returns. http://forums.pelicanparts.com/uploa...1172331616.jpg http://forums.pelicanparts.com/uploa...1172331641.jpg http://forums.pelicanparts.com/uploa...1172331700.jpg |
Brant, you take weight savings to a new level! :)
Hope your 914 motor didn't suffer catastrophic failure...if it did there are a few 2.0L's on the 914 classifieds right now. :( Very nice ride! |
Someone went to home depot and got themselves a holesaw. I thought swiss cheese was light yellow....not orange
Colin Chapman is smiling down on you from some cloud somewhere.
my father gave me the middle name of Colin at birth in respect to Mr. Chapman. |
I drove one a few weeks ago. Comfortable and fast as hell, 450 HP, 0-60 in 5 seconds! Big ceramic brakes, which did not help much getting a 5100 lbs beast down from the speed limiter to off ramp speeds on wet roads on winter tires ;) Well, that was off topic. The consensus must be that coil overs are overkill on a street car. If you like to spend money on the car the are better ways. |
Garibaldi,
Sorry for asking, but are you the member of PCA who was the 930 editor for the Panorama magazine? Or do I have my names mixed up? Thanks! |
Hi, well first off, my S8 is an 2001, not the brand new one, havent made it that big yet....and even if I did, I doubt Id drop that sort of coin on a car like that, and yes, I used to be the 930 tech guy for PCA and wrote stuff in Pano, and had the flat black 930, but those days are long gone, now I breed alpakas and have the largest PEZ dispenser collection in the continental US and trade low grade fetish films on craigslist......KIDDING! :D
hey Mr. Garibaldi,
I thought that might be you! The article about your 930 made quite an impression on me, especially the part where they said you sort of found the wheels in the garbage or something like that. I really liked reading your tech articles. You must run into a lot of your readers on this BB. |
I love the ride quality of my 74 with coil over conversion / 935 suspension:
http://forums.pelicanparts.com/uploa...1172564580.jpg http://forums.pelicanparts.com/uploa...1172564617.jpg http://forums.pelicanparts.com/uploa...1172564661.jpg http://forums.pelicanparts.com/uploa...1172564693.jpg http://forums.pelicanparts.com/uploa...1172564749.jpg I have dozens more suspension pics if you want them :) and I read some posts before about coil over 935 being bling but it rides a lot better than my 67 with 23 mm /28 mm torsion bars b/c it has 2 stage springs. |
Subscribing. SmileWavy
did you install brass, or needle bearings when you went to the rear coil overs and 935 front?
because I found the same improvement in ride quality from my needle bearings install. And thus theorize that the improvement in motion over poly-type suspension bushings can be attributed to ride quality (instead of the spring) What bushings are in that car Nice car by the way! brant |
| All times are GMT -8. The time now is 06:35 PM. |
