Porsche Crest Compression readings for a 930
Are these compression readings normal
My readings were:
120 psi on all cylinders (cold)
105 psi on all cylinders (hot)
My 1979 930 has "sc cams" in it.
Old 02-26-2007, 04:46 PM
RETIRED
Joe Bob's Avatar
They are low...but did you do the test right? With WIDE OPEN THROTTLE?
2012 ML350 3.0 Turbo Diesel
Old 02-26-2007, 05:38 PM
In all the testing I've done, I've never seen a significant difference in compression figures with the throttle open vs. closed. Also, compression tests are usually used for relative readings, not absolute. So even if there were a difference based on throttle position, as long as the throttle position is kept consistent throughout the test, the resulting numbers would be internally consistent.
That said, I think numbers around 105 psi sound a bit low, but I'd be far more concerned about cylinder-to-cylinder variation than absolute value. If you're concerned, follow up with a leakdown test -- that will tell you more about the extent and location of wear than you can learn from a compression test.
Rob
78 930
Old 02-26-2007, 05:54 PM
This test was done with the throttle fully open!
Old 02-26-2007, 07:16 PM
Gasoline User
1974carrera's Avatar
Those numbers don't sound too low for an engine with a 7.5:1 compression ratio...nicely consistent between cylinders, too.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 02-26-2007, 07:25 PM
