Recreational User
DarrylD's Avatar
Loose steering shaft.... this can't be good!
This how much the steering shaft moves on my '66 912!!! I seem to recall some aftermarket plastic sleeve that slipped down the shaft to fix this problem. Am I dreaming or is a complete tear-down and new bearing installation in my future? Is there even a bearing available for that early of 901 series car?
Old 02-22-2007, 11:30 PM
Darryl,
The shaft is loose without the steering wheel. Fitting the steeringwheel, with the spring and cupped washer tightens things up. Especially the washer is important, I drove mine for a while without one, and that gave some slop.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 02-22-2007, 11:42 PM
jluetjen's Avatar
There is supposed to be a bearing down there. I don't think you don't need to tear the complete steering assembly down, if I remember correctly (I did mine a few years ago), you don't need to take it down much further then you already have. Check out this article .
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-23-2007, 06:14 AM
That sleeve is for the 74 onwards setup. This thread describes the fix for the earlier type: HELP! Steering wheel bushing quickfix???
Peter
'13 981S
'73 911T
Old 02-23-2007, 06:24 AM
Unregistered
sammyg2's Avatar
No big deal. had the same thing on my SC. I Installed the new sleeve (from pelican) and I was back in bidbess.
Old 02-23-2007, 07:30 AM
RETIRED
Joe Bob's Avatar
15-20 minute job....easy peasey.....
2012 ML350 3.0 Turbo Diesel
Old 02-23-2007, 07:36 AM
Hey Darryl...been there, done that when I replaced the stock steering wheel with a MOMO on my '68 912...check the bottom of the wheel that you just removed...you'll find the sleeve there...
Marty
1983 silver 944 - sold to "Ontario Chris"
1968 white 912 - sold to Storm and Spencer in Long Island
Old 02-23-2007, 03:02 PM
randywebb's Avatar
Actually it is a Bigger Deal for an early car ... is this the '69?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-23-2007, 04:42 PM
Recreational User
DarrylD's Avatar
AH HA! It helps to have the correct steering wheel on the car!
I had taken the "trophy" wooden 901.xxx.xxx.xx numbered steering wheel off and popped a stripped-down 914.xxx.xxx.xx numbered one on it before leaving the car at the bodyshop for the frame straightening work. The spring is still on the correct 901 steering wheel but there isn't one on the 914 steering wheel!
Chalk it up to another thing learned the hard way!
Old 02-23-2007, 04:49 PM
stock wheel, spring and cup washer will fix that. the sleeve repair does not relate to early cars.
206 637 4071
Old 02-23-2007, 04:51 PM
