PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Front/bumper mounted oil cooler
Is there a bolt on solution for a front mounted oil cooler for the RSR replicas being built??
I would like to remove the stock oil cooler under the fender and put a front mounted unit behind the new bumper.
Something that comes with the cooler and the lines to connect to the stock hard lines...
Thank you!
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-20-2007, 02:11 PM
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGoil_pg7.htm#item28
Old 02-20-2007, 02:28 PM
Sorry, I posted the wrong link... I can't find it but I think Pelican carries the Elephant Racing front mounted oil cooler kits. I believe the kits come with the lines from the oil cooler to where the trombone connects to the oil lines.
Hope this helps.
Old 02-20-2007, 02:36 PM
group911@aol.co's Avatar
I have a factory front 930s cooler and it uses rubber lines that connects directly to the lines to the rear. I think yoiu can actually use another cooler in the fender.
Thanks,
Bob
group911@aol.com
Old 02-20-2007, 02:46 PM
Bill Verburg's Avatar
Actually you posted the correct link, the front mount kit is incorrectly described but the picture is correct.
the PEL-BBKT3 oil cooler is a front mount which includes the oil lines to the stock hardline. You would need to fab mounts for it.
theere are several different sizes and configurations for these coolers not listed in the Pelican page
Rob Fusi aka Muffinman did a nice writup on his install of one of the larger ones.
Rob Fusi oil cooler install
Bill Verburg
Old 02-20-2007, 02:50 PM
wachuko's Avatar
Excellent. Thank you all!!
I will sent a note and ask for the correct part number for the size of cooler I am looking for. The one in the Pelican ad seems to be the smaller one.
Bill, thank you for Rob's link.
Drive safe!
1967 - Porsche 912
Old 02-20-2007, 03:08 PM
wachuko's Avatar
Updating for those that might go this route:
Got my response from Pelican:
Hello There,
We do offer a SETRAB front mount oil cooler kit. Dimensions on cooler are 22.5\"L X 6.25\"H (cooler core) X 8.25\" overall height X 2\" thick. Installer will need to fabricate mounting brackets based on valance and space requirements. Hose is cut-to-length based on final oil cooler mounting position and hose-ends crimped on.
Kit comes with:
HD SETRAB oil cooler
30mm widemouth male fittings (2)
22mm crush washers (2)
30mm straight hose ends (3)
30mm 90 deg hose end (1)
8 ft of 7/8 HD oil line
1\" hose clamps (2)
rubber mount, (4)
Cost of kit is $828.95US
Sincerely,
John Chi
Drive safe!
1967 - Porsche 912
Old 02-24-2007, 08:08 PM
