Guest
Posts: n/a
Trailing Arm Bushings
I just finished removing the banana arms on my 72 911T to replace the trailing arm bushings. After installing the new poly bushings I noticed that the original steel sleeves do not fit through my new bushings[TWEEKS]. WHAT GIVES! Although the through bolts fit tight in the new bushings without the sleeves. It seems to me the sleeves should be used. Any input would be greatly appreciated.
Kevin Kipta "72" 911T/E |
Guest
Posts: n/a
I guess you should just be happy they fit ... you are, after all, at the mercy of the parts-picker when your order is filled ... and not everyone always gets what they order ...
And, it is quite commeon for poly-graphite bushings to eliminate the steel bushing and hasve the bolts ride directly in the plastic! I guess the 85-90 Durometer (Shorr A) poly is hard enough for there not to be a wear issue! ------------------ Warren Hall 1973 911S Targa |
