AFR Tuning - Here is my partial map
I started out with a baseline, generic injector opening time/AFR map and did some runs yesterday on the track with the datalogger running.
Based on the datalogs I picked around 30 datapoints where I had reasonable confidence that I was close or knew how to adjust the opening time to get the AFR dialed into those points. Those points are shaded in green on the image below. http://forums.pelicanparts.com/uploa...1172366634.gif I then interpolated the points in between. Those are not shaded. You'll notice I had limited data below 2000rpm (it doesn't spend much time there anyway) and nothing over 4500 (I am still breaking in the engine. Here's a "surface map" chart of that data. http://forums.pelicanparts.com/uploa...1172366671.jpg Some car details: 3.0L RoW heads smoothed to match 3.2 aluminum intake K&N filter (for a Dieselmax, the BIG BOY!) DR20 cams JE 11:1 pistons Twin-plugged Bursch headers into flowmaster dual-in/dual-out Fuel pressure is around 40psi 26# Accel injectors Hope that helps, would appreciate anyone else's posting of their maps too... |
| All times are GMT -8. The time now is 01:49 AM. |
