CIS Injection Puller Tool
Is there such an animal? I seem to recall seeing one at one point, but don't remember anymore. I always use a open end wrench smaller than the "nut" and a piece of wood to sort of pry it up and out. But, I have to think there is a better way.
Better yet, someone have one close to me in Westlake Village, California area to loan it to me.
Old 07-23-2007, 02:41 PM
fred cook's Avatar
Cool CIS Injector puller..........
I found a large nut with the same threads as the top of the CIS injectors. With the nut screwed on the injector, use a large screwdriver with a square shank to lever against the nut. The injectors practially jump out of the manifold!
Hope this helps.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-23-2007, 04:35 PM
M725ROB's Avatar
I use the 12mm and 14mm wrenches I have out anyway. I lay the closed end of the 14mm over a nearby intake nut, and hold the open end in my hand. Then I put the open end of the 12 on the injector and press down on the closed end, using the 14 as my fulcrum.
Once the injector is popped out I use these 2 wrenches to disconnect the fuel line from the injector. I squirt a little gel lube on the injector before reinstalling too, so next time it's even easier.
Rob
Old 07-23-2007, 04:50 PM
Yeah, Rob, your's is basically what I do. Except I like the idea of the 14 mm on the nut. That's the problem. I'm always trying to get this piece of wood to rest on something strong.
Fred, thanks too. On this one, I don't want to remove the injectors from the lines.
I did just do a search on the internet and found this crow's foot type of tool with a slot in it to put a tip of a screwdriver and lever it out. I guess I'll just stick with the old way. I do remember however a contraption type of tool. It's like this crow's foot, but it had a built in base to rest on something and a lever all connected - kind of like a corkscrew puller.
Thanks all.
Old 07-23-2007, 04:57 PM
tdatk's Avatar
I made this last spring to pull mine. It's a compression connector, a long screw, 2 fender washers, and a couple nuts...not mine
Tim
82 SC
90 C2
Yasowatt
Old 07-23-2007, 05:26 PM
You do not have permissi
john70t's Avatar
http://shoptoolsshoptools.com/shopexd.asp?id=2710
Should be the same for all Bosch CIS: Vw, Audi, etc... There also are slide-hammer types for diesels
The o-rings are culprits for vacuum leaks when they harden like a rock and shrink, especially in an air-cooled engine. Also check/replace the distributor boot to see if it has hardened.
Not sure what the best install lube is though....Silicone? I was once told to use a little oil, but I'd think petroleum products would not be compatable long-term with even synthetic o-rings.
Old 07-23-2007, 07:48 PM
KNS KNS is online now
tdatk,
What a surprise, I made a tool that looks almost exactly like that! Couldn't find anything else that worked.
Kurt
Old 07-23-2007, 08:19 PM
Now that's an interesting thought. As far as I know, they were dry from the factory. I believe it's the same answer for the o-ring under the throttle body. That said, one of the shops I was at used a non-hardening sealant for the throttle body o-ring in a tube with German writing all over it. Presumably also ok in heat and gasoline. They gave me some for my throttle body o-ring. There is not enough left for the injectors. Anyone out there with thoughts on it?
Old 07-24-2007, 02:13 PM
safe's Avatar
I have seen a tool in a workshop manual somewhere and that was like a fuel line with a handle on the other end.
The injectors could probably be pulled up by hand by the fuel line, if they break they should probably been replaced anyway.
Magnus
Old 07-24-2007, 03:00 PM
Senior Member
Superman's Avatar
Every o-ring I install from today through the rest of my life will be coated with silicon grease.
Mocha 1978 911SC. "Coco"
Old 07-24-2007, 03:03 PM
