no high or low beams
My 88 carrera high and low beams stop working. The problem started with a driver's tail light that was out. I changed the fuse and it worked. Now the high and low beams quit working. All the other lights work on the car and I changed the fuses for the high and low to no avail. Any suggestions? thanks in advance
Billy Crawford Last edited by bcr4d; 02-26-2007 at 06:44 PM.. |
Try pulling the headlight switch to the "on" position and then jiggling the stalk switch for the high beams. If the lights come on, then the stalk switch is bad. It's very common for the stalk switch to go bad.
1984 Targa |
reply
thanks for the quick reply, but excuse my ignorance, what's a stalk switch and where is it located?
Billy Crawford |
It's the combination high beam/turn signal switch on the left side of the steering column.
1984 Targa |
reply
dough, thanks scottb, I'll try it first thing in the morning. I'll let you know the outcome.
Billy Crawford |
Be sure you have the ignition key in the "on" position.
1984 Targa |
