-   -   Setting Points/Rotating Lobe - Thanks John Walker (http://forums.pelicanparts.com/porsche-911-technical-forum/332418-setting-points-rotating-lobe-thanks-john-walker.html)
HarryD 02-25-2007 02:20 PM
Originally posted by john walker's workshop on a different thread about adjusting valves
a wrench on the pulley nut, while pushing in on the right side of the belt, turns the engine over easy enough with the plugs in.
John,
This was a great way to move the distributor lobe so I could set my points. Thanks for the tip!
:) :cool:
911pcars 02-25-2007 07:02 PM
Another method is to shift into fifth. Release parking brake, then nudge vehicle forward while observing the distributor shaft/lobe.
Perform this on level ground.
Sherwood
