HarryD's Avatar
Setting Points/Rotating Lobe - Thanks John Walker
Originally posted by john walker's workshop on a different thread about adjusting valves
a wrench on the pulley nut, while pushing in on the right side of the belt, turns the engine over easy enough with the plugs in.
John,
This was a great way to move the distributor lobe so I could set my points. Thanks for the tip!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-25-2007, 02:20 PM
Another method is to shift into fifth. Release parking brake, then nudge vehicle forward while observing the distributor shaft/lobe.
Perform this on level ground.
Sherwood
Old 02-25-2007, 07:02 PM
