what a bunch of garbage
Secondly, with the 3.6, one just needs to source the engine and management, and I believe they're pretty much finished fishing for parts. Look at what Ben lists as the parts he needed for his turbo. Can all that be easily sourced? Third, as to big brakes, etc., well any increase in power should be fortified with larger brakes and other modifications to deal with that increase. |
We have enough people on this BBS that have turbocharged a 3.0 or installed a 3.6...so if you haven't done either... then don't comment.;) i enjoyed my aftermarket 3.0 turbo. My motor was already well on its way out but i threw it on anyway(poor leak-down). Sure it shortened its life a bit... but it was less then $2000. i already had a 3.0 and it transformed what i feel was an underpowered car. Later i put a 3.3 turbo in it. now THAT was fun. never been in a 3.6 car. so cant comment on that. |
There is a way to build something on the cheap side that wont last. However, building a turbo engine that you can take out and drive hard without having to worry if it will blow up is not cheap. P&C alone will be almost 3K. My ealier post was based on taking into consideration a large intercooler, p&c, and lots of other things.
I see prices on here that dont seem very realistic. 200 for a 3.2 intake would be very cheap. Every one that I have seen sell go for around 500 - 650. With the 3.6 you can just use the factory engine mgmt system with a harness that is available from Patrick Motorsports or build your own harness. The 3.6 conversion is a matter of a flywheel, exhaust, and that harness to make it work. |
People get caught up in the bigger picture debate of where the better bang for the buck is, in terms of improving 911 performance. But that seems out of place in this thread, where there's a very specific history (unless I'm missing something).
In_style has no motor at all -- as in a roller with a big hole in the back. He'd found a 3.6 with the conversion parts available for 7K Canadian (6K US?). He was concerned about budget and how the additional weight and power of a 3.6 would mandate a lot of other expensive upgrades. So from a bang for the buck perspective, you've got to figure in the cost of a 3.0 or 3.2, for starters. Because right now he doesn't have anything to put a turbocharger onto. Add to that the cost of a turbocharging system. And then someone explain to me how that's a less-than-US$6,000-solution -- that is also somehow less powerful and lighter than a 3.6 swap. I'm scratching my head. Yes, turbocharging can give you 3.6 power and 3.6 (and then some) weight. But those are the things that were scary for him in terms of brake and suspension upgrades -- so where does it get us? Maybe I'm missing something. But in_style seemed to have been scared off by what most of us would consider a real bargain. And then the solution he asked about in this thread seemed to compound the things that scared him away from the bargain in the first place. In my opinion, the problem wasn't so much with the solutions offered as with the odd logic behind the question. |
oh and one other thing. is that we all like what we have and for specific reasons for me it was all about the project and doing all of it myself with suggestions from some experienced people so it really is to each there own.. The 3.6 is a great combo and I was unawre of the deal he had found. if I were in his shoes for that kind of money I would have jumped on it.. but the question was can a 3.0 handle a turbo and the answer is yes!!!!!
I think someone mentioned engine weight:
I guess for this application the most important fact is that no engine currently exists.
The next most important information would be what exactly is the application? Do you have the skills and tools to do a 3.6L transplant or will installation be farmed out? What is your budget? What are you going to use the car for? What is your driving style? Some folks do not like turbos. They like the exhaust note of a N/A engine. That would eleminate any turbo or kit from the equasion. A turbo kit does not seem to be a good idea given that no engine exists. If turbocharging is desired then a 930 engine is logical. Given that a 3.6L engine and transplant kit are available at a good price that is the logical thing to do. If the budget does not include transmission, suspension, and brake upgrades then the power level needs to be kept low so that the car does not self destruct. A stock 3.6L or stock US 930 engine would be the most power I would put into a stock 911 chassis. |
I have made up my mind!!!
I am going to be buying the 3.6 and doing the conversion. I thanks everyone for their opinions, and have read every post through. I will order the motor today, and keep everyone posted. Thanks again. |
YEA!!
Good for you! |
where is sammyg2 when you need him. He is running a bolt-on turbo kit on his engine and seems quite happy
George |
this thread did get OT mid way.
a 3L is bulit proof and can still be reliable with one of the low-boost turbo kits, however this would not net 3.6 power a stock 3L making 3.6L power would have a shorter life. your 3.6L is a DEAL. they are incredible engines. and will hurl your earlier 911 down the road. most 911's have decent brakes, defiently good enough for street driving. most stock 911's also come with somewhat soft suspension, however switching to larger torison bars, and blisten sports is not that expensive, i believe someoen has ALL of the required bits on sale he on the forum for 1400...i mean all of them. 7000+1400+1600misc = 10 000 and you have yourself a hot rodded 911.. i might have missed some of the conversion kit.... even then, if you come in under 20k for your build you added up a BUNCH of good deals cheers Nick |
Was an external oil cooler mentioned? 3.6s require those.
Can a 3.0L handle a turbo?
Big reds:
I used front and rear 930 rotors: $500 on Ebay Germany Front and Rear big red Calipers: $1000 also on Ebay Set of pads: $100 Set of adapters: $300 Set of braided brake lines: $120 Adjustment of fron valance for 930 rotors: $250 Also something around $2300 You can find sometimes a whole Big red set including everything you need (except the adjustment of the front valance) for around $2200 to $2500 on Ebay (well in Germany, donno about US). Oil Cooler: I used stock 993 front fender cooler: $250 used, fan included Exhaust/Mufflers: I used stock 993 mufflers: came with engine, so did not need to pay for. |
| All times are GMT -8. The time now is 01:39 AM. |
